73 vs 74 Z1 forks and valving
- sdinse
18 May 2024 19:34
I would think that the change from the 73 design to 74 was for the better, but maybe not. Does anyone know what the end result (ride quality) of the 74 valves was?
73
74
73
74
1973 Z1 Since New
1973 Z1 Since New
Re: 73 vs 74 Z1 forks and valving
18 May 2024 20:44 - 18 May 2024 20:48
I have rebuilt a dozen or so pairs of forks from 74-75 up to 1978 and haven’t seen the damper you show as a 1974 Z1. They all are like the 1973 example
Last edit: 18 May 2024 20:48 by Mikaw.
- slmjim+Z1BEBE
19 May 2024 04:58 - 20 May 2024 05:00
Both designs are pictured in John Brookes' book (fourth edition) & onward, and in Kawasaki BULLETIN SER 74 GEN -16 detailed below.
Scuttlebutt was that changes were made to improve damping, and also to eliminate the irritating 'thunk' heard that early forks could produce when striking abrupt, raised edges such as driveway entrances at low speed.
General Service BULLETIN SER 74 GEN -16 documents differences, special tool for dis / reassembly, and changes to PN #'s (attached below). That bulletin also refers to BULLETIN SER 74 GEN 17 , which we done have. (If anyone has BULLETIN SER 74 GEN 17, could you please post it?) Thx.
Good Ridin'
slmjim & Z1BEBE
EDIT: posting as .jpg's.
Good Ridin'
slmjim & Z1BEBE
1973 ('72 builds) Z1 x2
1974 Z1-A x2
1975 Z1-B x2
1993 CB 750 Nighthawk x2
2009 ST1300A
www.kawasaki-z-classik.com
1974 Z1-A x2
1975 Z1-B x2
2009 ST1300A
Last edit: 20 May 2024 05:00 by slmjim+Z1BEBE.
The following user(s) said Thank You: Scirocco, sdinse
- sdinse
19 May 2024 13:54
Hmmmm . . . I get this from clicking on that PDF link:ForbiddenYou don't have permission to access this resource.Additionally, a 403 Forbidden error was encountered while trying to use an ErrorDocument to handle the request.
Any special reason for that?Thanks SlimJim & Z1BEBE, good info to know. I will put in the updated assembly.
1973 Z1 Since New
1973 Z1 Since New
- sdinse
The following user(s) said Thank You: slmjim+Z1BEBE
- sdinse
19 May 2024 14:37
OOPS!
After looking at the service bulletins I appears I got my 73 - 74 labelling backwards. Glad I have it straight now before I put it all back together.
1973 Z1 Since New
1973 Z1 Since New
- slmjim+Z1BEBE
20 May 2024 04:39 - 20 May 2024 04:57Sorrry. Our attachment-fu is stymied on this site sometimes.Hmmmm . . . I get this from clicking on that PDF link:ForbiddenYou don't have permission to access this resource.Additionally, a 403 Forbidden error was encountered while trying to use an ErrorDocument to handle the request.
We attached that .pdf file two different ways, because we're not sure how the site handles .pdf files. The live link seems broken. There's also an icon at the bottom of the post that is the same .pdf file. Clicking that enables downloading & viewing, or right-clicking enables 'save link as' function, at least on Firefox.
We'll re-scan as a .jpg. below & edit that other post if it's not too late.
Good Ridin'
slmjim & Z1BEBE
1974 Z1-A x2
1975 Z1-B x2
2009 ST1300A
1974 Z1-A x2
1975 Z1-B x2
2009 ST1300A
Last edit: 20 May 2024 04:57 by slmjim+Z1BEBE.
20 May 2024 05:19
- sdinse
20 May 2024 10:51
Thank you so much! These are much better quality than the ones I got from the Kaw Triples website. It's all very clear now. See what I did there? Ha Ha
1973 Z1 Since New
1973 Z1 Since New
- slmjim+Z1BEBE
21 May 2024 04:29If right clicking on the .pdf attachment (not the live link) & selecting 'save link as' doesn't work we can do that. Send us an email & we'll attach in response.
Good Ridin'
slmjim & Z1BEBE
1974 Z1-A x2
1975 Z1-B x2
2009 ST1300A
1974 Z1-A x2
1975 Z1-B x2
2009 ST1300A
21 May 2024 17:01
