Foot Pegs
  • AmStaFF
  • AmStaFF's Avatar Topic Author
Foot Pegs
02 May 2024 06:30
#898335
Hi Folks,
This question concerns a KZ1100A1- Shaft:
I am looking to change foot peg height and make it lower. I gave up on any rear shift as it seems too onerous.
the stock pegs have a huge ribbed rubber sleeve encapsulating the steel peg. It is too high and there is plenty of room to drop the elevation relative to the pivot and the steel peg. Has anyone put Goldwing pegs on or something similar where the top surface the foot rests on is as low as  possible relative to the pivot?
1981 KZ1100A
2021 Husq FE350
2023 KTM 890 Adventure S
  • Wookie58
  • Wookie58's Avatar
  • Moderator
  • Moderator
Re: Foot Pegs
02 May 2024 06:44
#898336
Worth bearing in mind that lowering the pegs will most likely reduce cornering clearance (don't know how excitable you are  )
  • AmStaFF
Re: Foot Pegs
02 May 2024 09:06
#898358
No, you didn’t understand my post. The stock pegs have a large (thick,tall) ribbed rubber sleeve. This can be lowered without reducing cornering clearance.
1981 KZ1100A
2021 Husq FE350
  • TexasKZ
  • TexasKZ's Avatar
Re: Foot Pegs
02 May 2024 12:32 - 02 May 2024 12:33
#898373
Have you tried flipping them upside down? The rubber looks thinner on the bottom. I suppose you could go after them with a hacksaw and slice those puppies down close to the metal.
Also, you could rip off the rubber and paint the metal with some bed liner material.
Last edit: 02 May 2024 12:33 by TexasKZ.
  • AmStaFF
Re: Foot Pegs
02 May 2024 13:56
#898378
Pretty clever-I’ll try it. I ordered a pair of eBay Huyabusa $10 pegs anyway.
The Moto Guzzi guys’ trick is Goldwing pegs and the U-bracket is the same width on many bikes.
thanks
1981 KZ1100A
2021 Husq FE350
