KZ1000 Air Cleaner Stay
  • Fox
  • Fox's Avatar Topic Author
01 Mar 2024 20:03
#895802
Hello,
do someone have a picture of this part on the bike please?
I don't know where it go ...
Thank you
1978 KZ1000-B2 LTD
1977 kz1000-B1 LTD
  • sf4t7
  • sf4t7's Avatar
Re: KZ1000 Air Cleaner Stay
01 Mar 2024 20:33
#895803
Don't have a photo right now, but it bolts to the bottom of the battery box near the front of the box making a shelf to the front (nearest the engine).  air cleaner housing rests on it.
Scotty
1974 Z1A
Yoshimura 987, 10.25:1
welded Z1 crank
Andrews 1X Cams
Delkevic 4 into 1
Superbike bars
530 conversion
The following user(s) said Thank You: Fox
  • Fox
01 Mar 2024 21:42
#895804
Thank you but the diagram tell me that too ...
1978 KZ1000-B2 LTD
1977 kz1000-B1 LTD
  • asphalt900
  • asphalt900's Avatar
02 Mar 2024 06:17
#895820
The lip goes down. should see witness marks where the two M6 retaining bolts hold it down. You will see where the split washer bit into it around the hole, this side up.
  • Cra-z1
  • Cra-z1's Avatar
02 Mar 2024 08:17
#895832
Yes lip down
  • Fox
10 Mar 2024 04:03
#896245
Hello,
i need a picture cause i don't find the place of this plate....
If someone...
1978 KZ1000-B2 LTD
1977 kz1000-B1 LTD
  • asphalt900
10 Mar 2024 06:17
#896247
Just above the upper rear engine mounting bolt there's a angle steel piece, two of the inner tapped M6 holes is where it goes. The bottom of the air box rests on it, pretty much centralized, protruding part towards engine and lipped section down.
  • Cra-z1
  • Cra-z1's Avatar
11 Mar 2024 08:16
#896284
This may give you an idea. The angle mount sits between the frame on the two engine mounts that have a tab to support the bracket. The battery box sits on the bracket with the rubber isolators then the air box stay sits on top. Im in the process of painting everything so the rubbers are not seen.
  • Fox
15 Mar 2024 17:57
#896448
Hello,
Thank you. No i never got this plate...
Perfect Thanks !
1978 KZ1000-B2 LTD
1977 kz1000-B1 LTD
  • Cra-z1
  • Cra-z1's Avatar
15 Mar 2024 19:49
#896453
I started with a bare frame and had to accumulate all the brackets. Was a bit confusing at first until I got all the parts in my hands. Frame is at the powder coaters and will be back in 10 days or so then I will assemble. if you need additional info I can do a part by part photo shoot.
