Clymer says to take off front wheel for brake pads
- treyhova
21 Jul 2023 07:43
Do I really need to take off the front wheel? Can’t I just remove the caliper?
79 KZ650 single disc.
- slayer61
- KZR FLAG RELAY CARRIER #62
Re: Clymer says to take off front wheel for brake pads
21 Jul 2023 07:53
You could probably try & find out. It is only 2 bolts after all. On my bike, I HAVE to take the calipers off to remove the front wheel.
21 Jul 2023 07:57
- Moose1800
21 Jul 2023 08:06
I don't know about the 650 but on a 900/1000 no need to remove the front wheel to change pads.
The following user(s) said Thank You: SWest, Warren3200gt, treyhova
- treyhova
21 Jul 2023 08:08
How do y’all get the front wheel off the ground for service? I’ve read that people will place a wooden block under the crank case? Do you use a jack to do that?
- JR
22 Jul 2023 06:44
"How do y’all get the front wheel off the ground for service? I’ve read that people will place a wooden block under the crank case? Do you use a jack to do that?"
You could do something like this
You could do do it with a single 2 x 4 under the steering head but one bump could send the whole thing sidways...and down
22 Jul 2023 08:12
Before I got my lift I used a bottle jack when it was on the center stand. Now I can do almost anything.
In order to remove my 110/90-19 wheel I have to remove the calipers and fender. The larger tire makes the bike more stable on and off the road and here in the desert that's a must.
- RonKZ650
22 Jul 2023 19:49
You definitely don't need to remove the wheel to replace pads. Remove the caliper, push back the piston, put in the pads. I can't believe any manual would say remove the wheel. Throw that manual in the trash.
23 Jul 2023 00:48The only thing I would add is before you push the piston back remove the reservoir cap on the master cylinder (when you push the piston back fluid is displaced into the reservoir, if the cap is on this can cause pressure and force fluid out of the vent)You definitely don't need to remove the wheel to replace pads. Remove the caliper, push back the piston, put in the pads. I can't believe any manual would say remove the wheel. Throw that manual in the trash.
23 Jul 2023 04:10
It's not all that difficult to remove the wheel and it exposes the brake pads for a change out. Like many other tasks it's just one way to do it.
23 Jul 2023 15:44
23 Jul 2023 16:06 - 23 Jul 2023 16:08
Last edit: 23 Jul 2023 16:08 by SWest.
