Replace or repair
  • rebreath
  • rebreath's Avatar Topic Author
Replace or repair
15 Jul 2023 05:56
#887243
1980 kz650 ltd is bike in question. Master cylinder was showing signs of seeping(paint and corrosion at right controls), so i yanked it and dropped into ultrasonic for cleaning. Not sure if i should try and source a rebuild kit(z1 doesnt seem to have the correct one, but gonna call on mon) or just replace with a modern one(not sure which one is the correct one for that task) but looks like it might involve some kind of plug update for brake light switch. And suggestions,recommendations or actual part sources are greatly appreciated.
  • Nessism
  • Nessism's Avatar
Re: Replace or repair
15 Jul 2023 06:21
#887245
You might want to check the aluminum bore for corrosion pitting.  Even if you find a proper kit, if the bore is damaged, you are dead in the water.
Bikes with dual front discs use a 5/8" bore master.  And single disc bikes take 14mm masters.  eBay has tons of cheap replacement China masters that are serviceable.  Master cylinders are very simple devices.  Or, you can hunt down a late(er) model master from a low mileage bike.  My bike is running a master from a 650 Ninja (the rectangular version, with mirror lug.)  There are lots of options.
[img
P1010741 by nessism , on Flickr
  • rebreath
15 Jul 2023 06:33
#887247
Thank you for the reply and suggestions.Definately will check the bore for pitting. Any chance you can narrow the age range on a substitute like yours. Your Pic looks like that style would work on mine as well. A ballpark year would help narrow the wide array of design and function.
  • Nessism
  • Nessism's Avatar
15 Jul 2023 06:36
#887249
I don't remember the year.  Search eBay for "650 ninja master" and "EX650 master" and you will find tons of them.  Just be sure to focus on the rectangular shape model.
The following user(s) said Thank You: rebreath
  • rebreath
18 Jul 2023 17:17
#887388
So master is not pitted and appears serviceable. Figured while i was cleaning and replacing what needs replacing that i would service the caliper as well. Sadly the piston is pitted. What are my replacement options as i cant seem to find a new piston and the kits dont include that part. Might need a whole new caliper if i cant locate one. Thoughts or suggestions
  • TexasKZ
  • TexasKZ's Avatar
18 Jul 2023 19:04
#887393
Check with Brakecrafters.
  • rebreath
25 Jul 2023 18:31
#887606
As always you folks are super helpful. Brakes completely rebuilt and converted to 5.1 fluid. No more paint corrosion or hydrophilic tendency. On to the next bit of upgrade now.......the headlight. What are my options for a headlight upgrade? Can i run an LED without crazy wiring changes?
  • Kelly E
  • Kelly E's Avatar
  • Never Give Up. Never Surrender
25 Jul 2023 21:51
#887607
I've been happy with a quality H4 lense and bulb. Plus it doesn't upset the charging system balance. To be honest if you need more than that maybe you shouldn't ride at night.
1974 Honda CB 550 K0
1977 Kawasaki KZ 1000 LTD
1978 Kawasaki KL 250
1980 Suzuki GS 1100E
1983 Honda CB 1100F
1984 Honda Sabre 700
1984 Honda Interceptor 1000
1990 Moto Guzzi 1000
And more
