Rear Differential (Shaft Drive) Gear Lube
- daveo
23 Jun 2023 14:33
It's been years since, and I think it's time for another rear diff lube change.
The last time I used a Valvoline Synthetic gear lube, I think...
What to use this time?
1982 KZ1100-A2 Sleeper 😎
Re: Rear Differential (Shaft Drive) Gear Lube
23 Jun 2023 16:04
Any SAE 80W-90 differential transmission lube will do.
23 Jun 2023 17:19
That is what I used in my Concours. I changed it and lubed the shaft splines every time I replaced the rear tire.
