Fork tube amount of oil?
  • gordone
  • gordone's Avatar Topic Author
29 Mar 2023 10:24 - 29 Mar 2023 10:25
#882148
How much oil should I add to the front suspension, 1981 KZ650-D4, with 1981 z750L engine?
Project:
Last edit: 29 Mar 2023 10:25 by gordone.
  • Nessism
  • Nessism's Avatar
  • gordone
Re: Fork tube amount of oil?
29 Mar 2023 11:33
#882150
So I can use what the service manual still, nothing have change when it comes to type of oil etc?
245cl +/- 4cl. Ok
Project:
  • F64
  • F64's Avatar
  • 81-KZ440D2
29 Mar 2023 13:12
#882153
Measure the amount of oil you dump out.
If you just add what is in the service manual you may have a bit too much.
I measure the level with a stiff rubber hose attached to a syringe. I would put a ziptie on the hose... 375mm from the bottom of the hose. I rest the bottom of the ziptie on the top of the fork with the rubber hose inside the fork. Then draw fluid out until i couldn't pull anymore out. Then i know the level of the oil inside the fork is 375mm from the top.
Racetech sells a tool that does this for $144.
I think you could make mine for less than $10 .
 photo:  racetech.com/page/id/70
81-KZ440-D2.
LIC, NY
  • Nessism
  • Nessism's Avatar
29 Mar 2023 13:51
#882154
Measuring the oil inside the fork is no assurance that amount is correct.  Never trust the previous owner...
I'd drain the oil, then fill to the level shown in the manual.  Get a small ruler, or mark a stick, and then use it as a dipstick to check level.  Very easy.
  • gordone
29 Mar 2023 22:08
#882171
Thank you all!
Project:
  • martin_csr
  • martin_csr's Avatar
30 Mar 2023 05:52 - 30 Mar 2023 06:07
#882178
Did you rebuild the forks? or just changing the oil? or only adding oil?
In the 1981 KZ650 FSM pdf:
Service Data page 1-13 (pdf pg 17).
Fork oil Table 2-12 on page 2-21 (pdf pg 51).
Fork Spring free length: Table 4-16 on page 4-15 (pdf pg 105).
Last edit: 30 Mar 2023 06:07 by martin_csr.
  • gordone
30 Mar 2023 06:48
#882181
Change the oil, but I rebuilded my kz650 fork with kz 750 innerfork 39093-1067 some years ago.
Do these effect the anount of oil?
Project:
  • blipco
  • blipco's Avatar
  • 2002 KZ1000P
30 Mar 2023 11:07
#882193
The oil height just creates an air spring of sorts. As long as the fork tube is filled to the specified level, I don’t think what internals you have inside matters that much. Whats important is that both forks are filled to equal levels.
Some people add oil to improve the situation of the forks bottoming out.
You could go slightly higher than what’s specified and if the forks are to stiff or harsh over bumps it’s an easy job to remove a little.
  • gordone
30 Mar 2023 13:28
#882199
Thank you for your advice!
things like that are not written in the service manual :)
Project:
  • blipco
  • blipco's Avatar
  • 2002 KZ1000P
30 Mar 2023 17:01 - 30 Mar 2023 17:02
#882206
Not my idea.
From Gary Jaehne's book. "Low $$$ Solution"
Last edit: 30 Mar 2023 17:02 by blipco.
  • gordone
30 Mar 2023 22:38
#882208
Very intresting!
always nice and intresting now more about the theory behind !
I have caps with a tiny whole for the gas valve… (are not using compressed air).
I was thinking drilling up the whole in size so I can add oil by taking out the screw I have inside the whole where the air valve was presented before?
It’s to much work unscrew the caps each time, adding some oil when trying to find the correct amount.
Project:
