Swapping stock KZ440 forks for longer, chopper style forks suggestions?
- MindbodySoell
28 Mar 2023 12:42
Looking to put extended fork tubes or an entire front end assembly onto my 1982 Kawasaki KZ440 frame to make it stretch out a bit, something like 6-8” over stock. Looks like the stock tubes are 33mm. Are there any fork tubes or front ends that you guys know of that could be used for this?
Re: Swapping stock KZ440 forks for longer, chopper style forks suggestions?
28 Mar 2023 12:55
Welcome to KZRider
No idea if anyone make a compatible tube for 6 to 8 over front end
Brings back memories of my 71 HD Sportster with 6 over tubes
Looked kool in 1971, Haven't see one in 40 years.
Good luck and welcome to the forum
28 Mar 2023 12:58 - 28 Mar 2023 13:00
Just my opinion but have you thought this through ? Most "chopper"style bikes also have the head stock angle pulled back to increase rake. If you simply extend the forks it will pitch the bike up at a crazy angle and the stand won't reach the ground until the bike falls over (you could extend it but it would be real long) as I say just my opinion
PS: if you want to extend the forks you could look at my build thread for how I did it
Last edit: 28 Mar 2023 13:00 by Wookie58.
- MindbodySoell
28 Mar 2023 13:10
The frame fabrication and rake has already been altered in a way to account for the change in height. Just need the fork assembly now.
- ronnieV
03 Apr 2023 06:20
I believe you contacted me on ebay for the extended forks I have for kz1000.I canceled all my auctions, tired of ebay
