KZ650 SR seat on KZ750 H LTD
  • Michel3007
  • Michel3007's Avatar Topic Author
13 Jan 2023 06:03
#878799
Does anybody know if a 650 SR seat might fit on a 750 H Ltd ?
At first glance, the frame don't look to different to me in terms of shape. The 750 might be slightly wider.
Cheers
KZ 750 H2 LTD 1981
GPZ750R1 1982
  • martin_csr
  • martin_csr's Avatar
Re: KZ650 SR seat on KZ750 H LTD
13 Jan 2023 07:22 - 14 Jan 2023 04:52
#878800
70s KZ650D-SR. My eyeballs say no. The hinges don't line up, plus the latch to rear hinge alignment is different.
Are you looking for a flatter seat or what?
If you mean CSR, then the KZ650-CSR frame & seat are the same as the 750H w the 1-piece seat; the 1980 750-H1 had an unusual 2-piece seat.
Last edit: 14 Jan 2023 04:52 by martin_csr.
  • Michel3007
13 Jan 2023 21:31
#878812
No, I am definitely talking about the SR and yes, looking for something flatter !
I kinda like the SR seat style and since I found one for cheap near where I live, I was considering trying the swap.
KZ 750 H2 LTD 1981
GPZ750R1 1982
  • hardrockminer
  • hardrockminer's Avatar
14 Jan 2023 04:40
#878814
The SR seat hinges are way forward compared to a C series 650.  If you buy the seat and it doesn't fit I will take it.  I have an SR that needs a seat.
  • martin_csr
14 Jan 2023 05:01 - 15 Jan 2023 05:23
#878817
Maybe look into a 750E seat. It's not ironing board flat but still flatter than the Ltd but is shaped to fit around a taillight cover & you may already know that. doh.
ps: EB daytrader-07 out of vietnam makes repro seats w powder-coated metal seat pans. one for the 750H is listed that's very similar in appearance to the SR. he provides a pic of the pan that was used as a template. shape of the seat kind of looks like the foam may not be very thick, though.
Last edit: 15 Jan 2023 05:23 by martin_csr.
The following user(s) said Thank You: Michel3007
  • Michel3007
16 Jan 2023 00:24
#878866
Thank you for the link Martin, it does look close. I will investigate.
As for the SR seat, I won't buy it in the end, after seeing pictures of the seatpan which is completely rusty...
I live in France Hardrockminer, the shipping would have cost you more than the seat itself :D
KZ 750 H2 LTD 1981
GPZ750R1 1982
  • martin_csr
16 Jan 2023 05:46 - 16 Jan 2023 05:48
#878872
Already mentioned, but most standard model seats are shaped to fit around a ducktail or rear cowl, including the 750E, so the fit won't be great on your motorcycle in that regard. I thought maybe that's why you were looking into the SR seat.  I think the E seat might fit as the frame is very similar to the 750H & the seats look similar on the underside. but the opening at the rear won't look right.
Last edit: 16 Jan 2023 05:48 by martin_csr.
