Q on sprocket size(s) KZ750/4 LTD
- Kubik
25 Dec 2022 07:44
Slowly recommissioning my 1980 KZ750/4, and while doing so, wonder about sprocket sizes used, F and R. It has the stock sprockets on, 13 teeth at front.
Any thoughts on what sizes work better? Perhaps 15T front? I don’t know, any suggestions welcome!
Keeping as is is okay too, if that’s the best.
Re: Q on sprocket size(s) KZ750/4 LTD
25 Dec 2022 08:46
Converting from 630 to 530 is highly recommended. Back in 1980, chain technology wasn't what it is today, thus the use of big heavy chains. In today's world, super bikes are using 520, or even smaller. There is no reason whatsoever to use a 630 today, other than for an "accurate" restoration.
Since 530 is smaller, you need to move to more sprocket teeth, and more chain links.
Your bike came with a 13T front and 32T rear sprockets, for a 2.46 gear ratio.
To convert to 530, add +3 to the front sprocket, so that means a 16T front sprocket.
For the rear sprocket, you have 16 x 2.46 = 39T (or 38T for a slightly lower rpm on the freeway)
Your stock 630 chain is 84 links. Each link on 630 is 6/8" long, so that means the chain is 84 x 6/8 = 63" long
530 chains are 5/8" long between links. That means you need 63 / (5/
= 100.8 links (use 102 links, to be safe)
www.z1enterprises.com/530-jtf513-series-...Four/all-models/1980
www.z1enterprises.com/530-jtr488-series-...Four/all-models/1980
The following user(s) said Thank You: KZNTX
