Mistake in Kawasaki service manual (KZ440A)?
- Michi
22 Dec 2022 14:23 - 22 Dec 2022 14:23
Hi, I have a KZ440A frame-up project which is mechanically almost all there, which needs a new drive chain. Kawasaki service manual specifies a 530-100 chain. I have an old rusty length of 530 lying around (I use the steel from old chains for various welding projects), and I've just been taking some measurements. I tried the old length of chain. Even with the chain adjusters all the way in, 100 links seems to be too short.
Nevertheless I've ordered a new one. However, it looks like the manual isn't gospel, this time. It's a straight KZ440A1, with original swinging arm as well. So I think when it arrives I might end up returning it right away. By the number of unreached sprocket teeth, it's 4 links short. I think it should be 530-104.
Anyone got a KZ440A who can confirm the drive chain length for me? 100 looks pretty impossible.
KZ440A LTD (1980)
Last edit: 22 Dec 2022 14:23 by Michi.
- krazee1
Re: Mistake in Kawasaki service manual (KZ440A)?
22 Dec 2022 14:28
Not impossible to have a mistake in a FSM, I discovered a few during my tenure as a Factory Mechanic. They are after all written by humans!
Mike
Mike
1974 Z1
1978 KZ1000 LTD
1976 KZ900B pile O parts
1980 KZ750E
1974 Z1
1978 KZ1000 LTD
1980 KZ750E
The following user(s) said Thank You: Wookie58, Michi
22 Dec 2022 14:29 - 22 Dec 2022 14:35
It seems like the manual is in error. The OEM parts fishe states 104 links. Check any on-line source of OEM parts, such as Partzilla.
Last edit: 22 Dec 2022 14:35 by Nessism.
The following user(s) said Thank You: Michi
- Michi
22 Dec 2022 16:55
Thanks all. Slightly disconcerting when Kawasaki corp isn't right! Looks like I'll be returning the chain unopened then. 104 links makes perfect sense.
KZ440A LTD (1980)
