Kickstand thread pitch?
  • Elfarm98648
  • Elfarm98648's Avatar Topic Author
19 Dec 2022 22:38
#878016
I am looking to fix the buggered threads on my kickstand and would like to know if anyone knew the thread size so I can be sure before I buy a tap/die for it? It appears to be around M8 but unsure of TPI.
1981 KZ750 H LTD
  • Elfarm98648
Re: Kickstand thread pitch?
20 Dec 2022 12:47
#878033
In case anyone ever needs this information it is actually M10x1.25
  • martin_csr
  • martin_csr's Avatar
21 Dec 2022 05:14 - 21 Dec 2022 05:16
#878063
I just logged in to say it's probably M10 & would've guessed 1.25. hee.
Also, maybe get a new or replacement bolt?
unless you've already done the repair, then never mind.
EB:  352951909984.  Kawasaki Bolt w locking nut $13.95T
Last edit: 21 Dec 2022 05:16 by martin_csr.
  • TexasKZ
  • TexasKZ's Avatar
21 Dec 2022 07:23 - 21 Dec 2022 07:26
#878070
Yup, still available new from Z1E, Partzilla, dealership, et cetera. That nut and bolt were used on about a buzillion different models from the Mach III to the ZX11.
However, I interpreted the op as referring to the threads in the bracket welded to the frame. If badly bungled, a different solution may be needed.
For less than $1 more, you can get a new spring, too.
www.z1enterprises.com/side-stand-spring-...2%20750%20LTD-4/1981
Last edit: 21 Dec 2022 07:26 by TexasKZ.
  • martin_csr
21 Dec 2022 07:44
#878071
Thanks. I was thinking if the threads on the frame are bad, then the bolt may be buggered as well.
  • Elfarm98648
21 Dec 2022 19:29
#878090
Tex and Martin, I did exactly that, I bought the Z1 kit with spring and went to install it and realized the threads in the kickstand were buggered so I wanted to run a tap through it before installing my shiny new bolt and locknut. Came out well, hopefully it lasts another 42 years like the original.
