KZ1000 CSR/GSXR fork swap
  • Andrew
  • Andrew's Avatar Topic Author
16 Dec 2022 00:51
#877858
Hi guys, I have a 81 KZ1000 CSR that I want to swap forks with a GSXR but here's the thing. I want to keep my original spoke wheel. Figured I'd need to make a custom axle/spacer witch I can get the machining done pretty easily. My main concern is with the calipers/disks.. keep them stock? Use the GSXR brakes?   Any of you guys have done this? Thanks!
  • Wookie58
  • Wookie58's Avatar
  • Away
  • Moderator
  • Moderator
Re: KZ1000 CSR/GSXR fork swap
16 Dec 2022 06:40
#877863
Don't forget there is the speedo drive to consider also
The following user(s) said Thank You: Andrew
