kz650B2a handgrips
- katit
kz650B2a handgrips
07 Nov 2022 08:43
Does anybody know what they should look like and who is a good supplier? The once I see on ebay go for like $100/pair??
Also, is right grip is a one piece with throttle tube?
R: 46019-038
L: 46075-028
R: 46019-038
L: 46075-028
- Warren3200gt
Last edit: 07 Nov 2022 11:10 by Warren3200gt.
Re: kz650B2a handgrips
07 Nov 2022 12:06 - 07 Nov 2022 13:07
Z1 handgribs
www.fastriders.de/Handgriffe-Gummi-Schwarz_1
KZ650/900/1000 handgribs
www.fastriders.de/Handgriffe-Gummi-Schwarz_2
Edit: Warren is right! Sorry, It was my foult, have switch the links to the corret handgrips now.
Last edit: 07 Nov 2022 13:07 by Scirocco.
The following user(s) said Thank You: Warren3200gt, katit
- Warren3200gt
07 Nov 2022 12:10
Disagree re 650 hand grips Scirocco, the picture I posted is from the 650 I bought new in 77 and still own.
The following user(s) said Thank You: katit
07 Nov 2022 14:08 - 08 Nov 2022 06:15
The RH grip is sold w the throttle tube as an assembly. I've seen a RH grip w/o the throttle tube on EB, possibly for a KZ400. I forget & don't remember what it looked like.
Here's the LH grip. has pic. I guess this looks like the original part on a 70s 650. $33 + sh.
www.partzilla.com/product/kawasaki/46075...f4953b0372a1d6388486
And the RH grip assy (unavailable).
www.partzilla.com/product/kawasaki/46019...f4953b0372a1d6388486
Last edit: 08 Nov 2022 06:15 by martin_csr.
- katit
15 Nov 2022 17:00
Ordered set from Japan on ebay. Quality look superb. Listed as KZ650. But I think it's wrong throttle one?? There was no detailed pic and I didn't see it's 1-cable.
I will check I may just use my old tube (metal). But who is wrong?
- katit
15 Nov 2022 18:15
Seller claims difference in 2 cable vs 1 cable is due to "year". Was there "KZ650" which used one cable throttle?
- Warren3200gt
15 Nov 2022 20:41 - 15 Nov 2022 23:27
Seller is wrong. Both single cable and grip pattern are wrong for z650b.
That looks like a 80"s throttle tube and grip pattern.
82 Z1000j. Single cable.
77 z650b Twin cable.
Last edit: 15 Nov 2022 23:27 by Warren3200gt.
- katit
15 Nov 2022 21:43
Is it possible any newer kz650s used those or they all were 2 cable
- Warren3200gt
15 Nov 2022 23:24
Don't know anything about the later models but it would seem likely those kind of parts would be shared amongst various models of the year.
Check the cmsnl and khi parts diagrams.
16 Nov 2022 05:35
Partzilla shows the same two-cable part number for the 650B, C, D, &E1, and a plethora of other models.
www.partzilla.com/product/kawasaki/46019...61f02a85415744b8f589
16 Nov 2022 05:59 - 16 Nov 2022 09:53
That appears to be part # 46019-1015 & it was used on a number of 81-on KZ models, especially 82-on.
82-83 KZ650-CSRs came w BS32 carburetors & use the -1015 throttle grip shown >> my neighbor had an 82 w the -1015 grip.
My 81 KZ650-CSR has VM24 carburetors w the earlier -038 throttle grip assy.
Models w CV carburetors sometimes only use one throttle cable.
From the 1982 KZ650-H2 CSR diagrams: 46019-1015
www.partzilla.com/product/kawasaki/46019...80fb1f9d449685225d8a
Last edit: 16 Nov 2022 09:53 by martin_csr.
