Rear rim aligment
- alzo
Rear rim aligment
03 Nov 2022 01:05
Hi guys,
How do you setup rear rim alignment if you buy new rim and spokes?
Old rear tire is not available.
I know that frond should be in center alignment.
I couldn't find any data in the manual about rear rim/hub offset.
Thanks.
Thanks.
Gentlemen, you had my curiosity… but now you have my attention!
Re: Rear rim aligment
03 Nov 2022 12:47 - 05 Nov 2022 06:19
By alzo: Old rear tire is not available.
Dunlop motorcycle tires lists the D404 110/90-18 for the KZ650B rear wheel.
This may not be a very good tire, but you should be able to find a different tire elsewhere.
Bridgestone Battlax BT46 for example.
edit: if you can't find the correct stock size tire, use a motorcycle tire cross-reference to find a suitable close match. or search your motorcycle model on the tire mfgs websites.
Last edit: 05 Nov 2022 06:19 by martin_csr.
03 Nov 2022 15:52
The hub should be centered. It will naturally move to this position when you lace the wheel and tighten the spokes. Use a spoke torque wrench to ensure consistent torque around the wheel. Check the runout and adjust spokes if necessary.
- alzo
04 Nov 2022 00:42
Thanks guys..
