Brake lines
  • bugkiller82
  • bugkiller82's Avatar Topic Author
Brake lines
30 Aug 2022 17:54
#873117
Looking for some brake lines for the 1978 KZ 650 SR.
Is there any good Source out there?
Thanks
  • slayer61
  • slayer61's Avatar
  • KZR FLAG RELAY CARRIER #62
Re: Brake lines
31 Aug 2022 07:28
#873134
I got mine from Z1E. Good stuff. Buy with confidence.
www.z1enterprises.com/
The following user(s) said Thank You: bugkiller82
  • Nessism
  • Nessism's Avatar
Re: Brake lines
31 Aug 2022 16:22
#873149
You can make your own lines from Earl's parts fairly easily.  They are made in the USA, and you can customize based on your bars and desired routing method.  My 750 build thread has a tutorial inside showing how easy they are to assemble.
  • Dr. Gamma
  • Dr. Gamma's Avatar
Re: Brake lines
31 Aug 2022 16:57
#873152
I second Nessism comment. You can't beat Earl's Supply for the highest quality braided steel brake hose and fittings!!! You can make your brake lines the exact length you want.
Over 95% of the race cars in this country are plumbed with Earl's hose and fittings. That should tell you something about their quality!!!
1986 RG500G 2 stroke terror.
The following user(s) said Thank You: Nessism, bugkiller82
  • daveo
  • daveo's Avatar
  • Premium Member
  • Premium Member
Re: Brake lines
01 Sep 2022 12:10
#873184
Installed HEL brake lines on my KZ1100 in 2016
us.helperformance.com/motorcycle/braided...ke-lines/kawasaki/kz
1982 KZ1100-A2/1170 sleeper 😀
  • danr123
  • danr123's Avatar
Re: Brake lines
02 Sep 2022 23:18
#873274
ME TO I PURCHASE ON KZ ENTERPRISE FOR MY FRONT BRAKE LINE
BUT IT'S BETTER TO USE A NEW PARTS THE ORIGINAL PARTS
IF NOT THE K1ENTERPRISE SALE THE HOSE FOR BRAKE LINE  BUT
THIS HOSE IS NOT THE SAME DIAMETER ON THE ORIGINAL  I FILL A COAT ON HOSE TO EXPAND A DIAMETER
AND IT'S GOOD
HELLO
MY VINTAGE KAWASAKI KZ400 1978
