'82 J2 - need front master cylinder
- The_Raven
23 Aug 2022 11:03
Hi all,
My master is pretty bad, the fluid is all crystallized, I need to replace it. I can't find an OEM master anywhere, except for some stuff on eBay which mostly looks super-sketchy. Anybody got a line on a decent replacement or an OEM piece? I'd ask for NOS, but I'd probably have to give up an organ or two.
TIA!
TIA!
-Mark P.
Salem, MA
Widowmaker, 1982 KZ1000J2 @1100cc
Red Scare, 1994 Honda VF750C Magna
I intend to die from living.
Salem, MA
- Warren3200gt
Re: '82 J2 - need front master cylinder
23 Aug 2022 11:34
Any twin disc 5/8ths master will do the job. Remember the brake light switch is built in to the mc on J's.
The following user(s) said Thank You: The_Raven
- The_Raven
23 Aug 2022 17:24
Is the front master specific to the J, or can I use stuff from a police model? I'm sure there are some good generic pieces out there, but I'm seeing stuff on eBay from companies I've never heard of that I wouldn't put on a scooter. Plus, I might need to replace the calipers if the pistons are trash (haven't looked yet), and I'd like to do it all in one deal with OEM if it's possible.
-Mark P.
Salem, MA
Salem, MA
23 Aug 2022 19:23
The P series copsicle master cylinder should work just fine.
- The_Raven
24 Aug 2022 06:01 - 24 Aug 2022 08:00
So after some digging I found this on eBay...
Link
It's a rebuilt master off an 750-E1, it's the same assembly.
Thanks to OKC_Kent for providing the Zedder info.
Part # = 43015-1032
Part Description = CYLINDER ASSEMBLY,FRONT
Model Count = 12
Model Name Year Size Description Type
KZ750-E1 80 750 750 STANDARD-4 STREET
KZ750-E2 81 750 750 STANDARD-4 STREET
KZ750-E3 82 750 750 STANDARD-4 STREET
KZ1000-J1 81 1000 KZ1000 J MODEL STREET
KZ1000-J2 82 1000 KZ1000 J MODEL STREET
KZ1000-E1 79 1000 KZ1000 ST STREET
KZ1000-E2 80 1000 KZ1000 SHAFT STREET
KZ1100-A1 81 1100 1100 SHAFT TOURING
KZ1100-A2 82 1100 1100 SHAFT TOURING
KZ1100-A3 83 1100 1100 SHAFT TOURING
KZ1300-A1 79 1290 KZ1300 STANDARD STREET
KZ1300-A2 80 1290 KZ1300 STANDARD STREET
Link
Part # = 43015-1032
Model Count = 12
-Mark P.
Salem, MA
Salem, MA
Last edit: 24 Aug 2022 08:00 by The_Raven. Reason: formatting
