KZ305 handlebar replacement
  • Vano
  • Vano's Avatar Topic Author
09 Aug 2022 21:36
#871954
I have successfully replaced the OEM handlebar on 1987 KZ305B with EMGO "Chrome 7/8 in Yamaha XS1/XS2 650 Style handlebar" 23-12548. It is a bit shorter then OEM but gives better angles for hands. The control area is specified as 7", which is a bit short and seems to be not enough on paper but KZ305 controls fit with no problem with (very) little room to spare. I had to drill one 4mm hole to the right control assembly key at 6 1/4" from the end. It was easy to do. The knurling on the handlebar is just in the right place - centers of the clamps. The OEM turn signals fit nicely and do not interfere with the gas tank with comfortable margins.
Overall it is a good alternative to the OEM handlebar, which is hard to get in any condition.
The following user(s) said Thank You: TexasKZ, 82KZ305Belt
