Fork stem question/part
  • rscone11
  • rscone11's Avatar Topic Author
27 Jul 2022 07:12
#871115
good morning gents,
Can someone assist with the order these parts go together? From what I see #40 should be like a dust cover over the bearing and goes below the #4(head steering stem)? Is that correct. Does anyone have a spare #40 (oil seal) since it is no longer available? #39 goes above 40 and 9 on top them the head?
Thanks in advance.
  • TexasKZ
  • TexasKZ's Avatar
Re: Fork stem question/part
27 Jul 2022 07:32
#871117
Page 184 in the service manual shows a cutaway drawing of the assembled parts.
www.kzrider.com/modules/ServiceManuals/K...Service%20Manual.pdf
The following user(s) said Thank You: rscone11
  • rscone11
27 Jul 2022 07:46
#871118
Thank you Texas KZ, so it appears I am missing the upper inner race and the stem cap. Does anyone have these parts available or laying around they could sell. The diagram from partzilla doesn't show available or in the diagram.
Thanks for the help.
  • Mikaw
  • Mikaw's Avatar
27 Jul 2022 09:16
#871124
I’ll look when I get home. About 4:30 eastern time.
  • Mikaw
  • Mikaw's Avatar
27 Jul 2022 18:25
#871166
Are these what your looking for
  • z1kzonly
  • z1kzonly's Avatar
27 Jul 2022 18:51
#871168
Hi Matt. Might be this oil seal that sits on base of tripie stem before the bottom race gets put on?
  • DoctoRot
  • DoctoRot's Avatar
28 Jul 2022 02:41
#871178
new headstock bearings are cheap and come with all the seals. why not install new?
  • rscone11
28 Jul 2022 04:11
#871181
Hi Matt, yes I believe those are correct.
@Doctorot , I would be glad to install new but I am unable to find them for sale. Do you have a site? I have searched all the most popular Z1 sites, ZI ent. Z1 power, partzilla, Doremi.
Thanks.
  • rscone11
28 Jul 2022 04:12
#871182
@Z1kzonly
I have that seal on the headstock. I also have the ball bearings that are needed.
  • Mikaw
  • Mikaw's Avatar
28 Jul 2022 04:34
#871186
I went back to the breakdown you posted, appears to be a Z1, correct? If so the cap I have isn’t correct. The Z1 is more dome shaped. It’s still available from KHI. Are you looking to upgrade to Timken (tapered) bearings?
www.partzilla.com/product/kawasaki/46098-010
  • TexasKZ
  • TexasKZ's Avatar
28 Jul 2022 08:14 - 28 Jul 2022 08:16
#871195
I do not know which year and model you have, but AllBalls Racing have bearings for a 1978 Kz1000B in stock. These are tapered roller bearings which most folks prefer to the old ball bearing setup.
www.allballsracing.com/22-1014.html
It would be easier for folks to offer help if we knew for sure exactly which year and model you have.
Last edit: 28 Jul 2022 08:16 by TexasKZ.
  • Mikaw
  • Mikaw's Avatar
28 Jul 2022 08:18 - 28 Jul 2022 08:20
#871196
I was just posting that thank you.
Here’s an alternate. You can by your choice of brand. Will have to contact allballs to see if they sell the seals À la cart.
Credit Wookie for finding the following
Last edit: 28 Jul 2022 08:20 by Mikaw.
