Disc Lock for Solid Discs
  • StuartR
  • StuartR's Avatar Topic Author
  • 1977 KZ650
27 Jun 2022 15:14 - 29 Jun 2022 18:22
#869437
Hi,  I have recently purchased a 1977 KZ650 with solid discs so I am struggling to get a disc lock or simular that will fit.
I have a chain when parked at home but I am looking for something smaller I can carry with me to lock the bike when I park it up to pop in to a shop or stop for coffee etc.  Any suggestions ?
Many thanks in advance
Last edit: 29 Jun 2022 18:22 by Street Fighter LTD.
Re: Disc Lock for Solid Discs
27 Jun 2022 19:30
#869446
I have a 1977 KZ650-C1.  When I lock it up I use the lock on the steering stem, but I also lock the rear wheel as shown below.  Ed
The following user(s) said Thank You: Wookie58, StuartR
  • rstnick
  • rstnick's Avatar
  • Premium Member
  • Premium Member
28 Jun 2022 14:21 - 28 Jun 2022 14:24
#869493
Welcome.
Good choice for a motorcycle.
I have this one that fits on the rear rotor.
It's an old one I found, no brand name.
[img
[img
Rob
CANADA
2000 ZRX1100
2011 Ninja 250R - Wife's
2005 z750s
1978 KZ1000 project
1983 KZ1000R2
Last edit: 28 Jun 2022 14:24 by rstnick.
The following user(s) said Thank You: StuartR
  • StuartR
  • 1977 KZ650
28 Jun 2022 16:02
#869499
Shame that's not branded as searching by size is not that easy.
I also like that padlock idea so I need to find one exactly the right dimensions and one that unhooks from the lock chamber to get it in that small gap behind.
  • TexasKZ
  • TexasKZ's Avatar
28 Jun 2022 16:44 - 28 Jun 2022 16:46
#869500
www.kryptonitelock.com/en/products/produ...html?type=motorcycle
I have used other Kryptonite locks, and been well pleased with them.
Here is the rest of their line.   www.kryptonitelock.com/en/locks-landing/...ails-motorcycle.html
Last edit: 28 Jun 2022 16:46 by TexasKZ.
  • Irish Yobbo
  • Irish Yobbo's Avatar
29 Jun 2022 18:11
#869577
A few things to note:
- Disc locks are better than nothing, but are very easy to bypass. My bike was stolen with a disc lock on it. For the case you're talking about (shops) it's probably enough.
- Disc locks work better on the rear wheel. Two people can wheel a bike away with ease by lifting the front. If it's on the rear it's difficult even if the steering lock is bypassed.
- Most cast 'stapler style' disc locks are little more than an annoyance to thieves. Many can be bent silently in a few seconds with a pry bar (which can warp the disc but won't stop a theft). The ones that can't be bent can usually be forced with a bolt extractor , or even cut silently with a small blade or cable saw. A traditional padlock or similar with a hardened shackle or a round-body type would be better
1981 KZ750 LTD
  • StuartR
  • 1977 KZ650
30 Jun 2022 00:57
#869597
Thanks for this, I think it may well fit "3.46” (88mm) maximum distance for disc rotor insertion".
  • slmjim+Z1BEBE
  • slmjim+Z1BEBE's Avatar
30 Jun 2022 04:55
#869601
As we don't know the size of the hole the lock must pass through, a hitch receiver lock that has a standard 5/8" shaft may be too large to pass through.  Otherwise, it's small enough to slip into a pocket.  The linked item is one example of many.  It has a very secure barrel lock.
www.etrailer.com/Trailer-Hitch-Lock/Blue-Ox/BX8858.html
Good Ridin'
slmjim & Z1BEBE
USA
1973 ('72 builds) Z1 x2
1974 Z1-A x2
1975 Z1-B x2
1993 CB 750 Nighthawk
2009 ST1300A
www.kawasaki-z-classik.com
  • rstnick
  • rstnick's Avatar
  • Premium Member
  • Premium Member
30 Jun 2022 07:55
#869611
I sometimes use the Kryptonite lock on the right on the KZ650.
Through the front wheel on either side of the forks.
The Abus disk lock fits the ZRX, not sure if it fits the KZ...
[IMG
Rob
CANADA
2000 ZRX1100
2005 z750s
1978 KZ1000 project
1983 KZ1000R2
  • StuartR
  • 1977 KZ650
30 Jun 2022 09:36
#869622
I have something similar for when the bike is at home but I'm wanting something I can put in my pocket for when out and about
  • Street Fighter LTD
  • Street Fighter LTD's Avatar
  • Moderator
  • Moderator
30 Jun 2022 18:05
#869648
A bracket  is or was available to hold the big lock on your bike . It mounted to the rear top shock mount
I have one somewhere  I will find it and post a picture
