KZ440 sprocket carrier bearing question
- Sdaniels2010
18 Jun 2022 08:06
The bearing has a retaining ring...wondering if it is removable without destroying it.
1981 KZ440 A2 LTD
Re: KZ440 sprocket carrier bearing question
18 Jun 2022 11:21So,what´s the problem. Remove the retaining ring, heat up the carrier case around the outer bearing shell and some wags with a drift punch on the inner shell do the job.The bearing has a retaining ring...wondering if it is removable without destroying it.
The following user(s) said Thank You: Sdaniels2010
