1977 KZ1000 dual front brakes
  • Rick S
  • Rick S's Avatar Topic Author
18 May 2022 18:52
#867287
I’ve done some research regarding dual front brakes for my 1977 KZ 1000.  From what I can tell is that you can use the same front brake by reversing a part of it and using a 5/8 MC.  It appears the rotors are a hunk of steel so any recommendations on a lighter set?   Thanks.
  • hardrockminer
  • hardrockminer's Avatar
Re: 1977 KZ1000 dual front brakes
19 May 2022 04:45
#867300
The rotors on a dual brake setup are thinner.  You should be able to use the rotors off an LTD version.
  • Rick S
19 May 2022 10:20
#867320
I found some EBC rotors for a LTD.  I continue to wonder about calipers and fitment. I need to check and see what the difference is between the LTD  and the standard KZ one.  Thanks.
  • Moose1800
  • Moose1800's Avatar
19 May 2022 10:21
#867321
I have both front rotors from a 77 and up LTD and also a freshly rebuilt 5/8 master cylinder I might consider selling if your interested.
  • Rick S
22 May 2022 07:52
#867480
PM sent
  • Mikaw
  • Mikaw's Avatar
22 May 2022 09:30 - 22 May 2022 10:15
#867489
Your 1977 kz1000a uses the same caliper as the kz900 with the hard pipe connector. The calipers are reversible, but the brackets are not. Beyond the 5/8 M/C you will need a dual brake hose splitter or a dual banjo bolt. Also a right hand caliper bracket. Rotors from an LTD any year from ‘76 - ‘80, A dual brake hose kit. Caliper to hub bolts and locking taps. RH hose locating fender bracket, and grommet.
dual hose kit evilbay number 234371750511
dual banjo bold 183152109332
dual brake splitter 384894545266
Master cylinder 115141355864
These are correct 1977 rotors, pending the year of your bike build 294968691848
Look here for rotor to hub hardware     www.partzilla.com/catalog/kawasaki/motor...tire-hub-77-78-b1-b2
Caliper slider bolts (caliper to bracket) z-fever.de/shop/en/product_info.php?info...83_bolt-caliper.html
Bracket to fork bolt,18,19,20.  www.partzilla.com/catalog/kawasaki/motor...nt-brake-77-78-b1-b2
Front M/C. You can call and ask about used parts also.  www.johnnysvintagemotorcycle.com/product...-cylinder-kz900-ltd/
Last edit: 22 May 2022 10:15 by Mikaw.
  • Mikaw
  • Mikaw's Avatar
22 May 2022 20:57
#867538
Wrong caliper but correct bracket for a right hand upgrade.
evilbay item number 154137584599
  • Moose1800
23 May 2022 08:03 - 23 May 2022 08:08
#867570
PM sent
   I got your PM, I have everything that's listed in this ebay add plus both rotors from a 77/79 1000 LTD >  ebay 153425065546 The master cylinder in this ebay add is not complete and looks like junk to me. The 5/8 M/C I have is a fresh rebuild and the calipers I have ( both left & right ) need rebuilt and painted but both are in better shape than anything you will find on ebay. $400 for everything I have.
I can clean,paint,and rebuild the calipers for the price of the rebuild kits plus my time to do so.
Last edit: 23 May 2022 08:08 by Moose1800.
