1981 KZ440 LTD master cylinder bore size
- Sdaniels2010
30 Apr 2022 17:57
Can someone confirm the master cylinder is a 14mm? The paint is flaking on mine & I can't make out anything on the mc body. Service manual doesn't list the bore size either.
1981 KZ440 A2 LTD
Re: 1981 KZ440 LTD master cylinder bore size
30 Apr 2022 18:33
The following user(s) said Thank You: Sdaniels2010
- Sdaniels2010
01 May 2022 03:13
I was looking in the wrong section...disassembly doesn't have the service specs. Thank you very much!
1981 KZ440 A2 LTD
