1981 KZ650-D4 - gas tank?
- gordone
14 Apr 2022 10:01 - 14 Apr 2022 10:02
I have a 1981 KZ650-D4 (The SR series of KZ650 was internally known as the Kawasaki KZ650D.)
wherr the gas tank could be larger.,,
What larger gas tank will fig the frame without modifications?
thank you.
1981 KZ650-D4
thank you.
1981 KZ650-D4
Project:
Project:
Last edit: 14 Apr 2022 10:02 by gordone.
- gordone
Re: 1981 KZ650-D4 - gas tank?
15 Apr 2022 01:32
F2 has 16,8l / 4,4 gallon, will it fit the frame and brackets, anybody know?
right now I have 14l / 3.7 gallon.
Project:
Project:
15 Apr 2022 04:45
I think the standard tank is 16.5 liters. So you are not gaining much with this alternative.
- rstnick
15 Apr 2022 07:43
I've seen many D model 650s with B/C/F tanks, and vice versa, so I think mounting is no issue.
I know Rick/bensherb on the 650info forum has a D tank on his B model.
I will ask him...
I will ask him...
Rob
CANADA
2000 ZRX1100
2011 Ninja 250R - Wife's
2005 z750s
1978 KZ1000 project
1983 KZ1000R2 Project
CANADA
2000 ZRX1100
2005 z750s
1978 KZ1000 project
- gordone
15 Apr 2022 10:55
Thank you, I think can gain 2,8l?
Project:
Project:
- rstnick
15 Apr 2022 16:09
Yes, Rick confirms it's a straight swap, D tank on the B/C/F models or their tank on a D model.
Rob
CANADA
2000 ZRX1100
2005 z750s
1978 KZ1000 project
CANADA
2000 ZRX1100
2005 z750s
1978 KZ1000 project
- rstnick
15 Apr 2022 16:45
Rob
CANADA
2000 ZRX1100
2005 z750s
1978 KZ1000 project
CANADA
2000 ZRX1100
2005 z750s
1978 KZ1000 project
- gordone
16 Apr 2022 00:39 - 16 Apr 2022 00:40
Project:
Project:
Last edit: 16 Apr 2022 00:40 by gordone.
- gordone
16 Apr 2022 00:41 - 16 Apr 2022 00:41
Project:
Project:
Last edit: 16 Apr 2022 00:41 by gordone.
16 Apr 2022 04:18
Side covers for a B will not fit a D. Different mount holes. Gas tanks are interchangeable.
- rstnick
16 Apr 2022 12:29You can use a B, C or F model tank, they are the same size.it’s a F tank I must consider then to gain 2,8l?
The tank badges are different through the years, 1977 & '78 having recessed badges and all caps KAWASAKI, and '79 and later not recessed and Kawasaki spelt with lower case letters too.
Rob
CANADA
2000 ZRX1100
2005 z750s
1978 KZ1000 project
CANADA
2000 ZRX1100
2005 z750s
1978 KZ1000 project
- gordone
17 Apr 2022 11:18
Do you witch of them is largest when it comes to gas capacity?
Maybe I should stick to what I have…
Project:
Project:
