What is these part called?
  • gordone
  • gordone's Avatar Topic Author
26 Mar 2022 03:52
#864312
Please photo below, what is the name for these part?
what is the right way of measure the size?
Project:
  • kzstreetfighter71
  • kzstreetfighter71's Avatar
  • Atlantic West Coast
Re: What is these part called?
26 Mar 2022 04:23 - 26 Mar 2022 04:24
#864313
"E type" circlip my good man and by the internal diameter.
Last edit: 26 Mar 2022 04:24 by kzstreetfighter71.
  • martin_csr
  • martin_csr's Avatar
26 Mar 2022 07:12 - 26 Mar 2022 08:03
#864318
Where are those on the motorcycle? just curious.  I looked thru the diagrams for the 1981 KZ650-CSR but only found 1.
Here's a sample Kawasaki circlip at Cmsnl.com in the UK. #92033-036:   www.cmsnl.com/products/circlip10mm_92033036/
#92033-036 is superseded by 482J0100:  www.cmsnl.com/products/circlip-10mm_482j0100/
note: these are just examples. I have no idea what size you have.
Last edit: 26 Mar 2022 08:03 by martin_csr.
  • Ian_B
  • Ian_B's Avatar
26 Mar 2022 07:15 - 26 Mar 2022 07:16
#864319
E clip, C clip - plenty of suppliers, here's one at random: eBay item number: 271704858948
Also in stainless: eBay item number: 224303815118
Ian
Last edit: 26 Mar 2022 07:16 by Ian_B.
  • Mikaw
  • Mikaw's Avatar
26 Mar 2022 07:42
#864320
Taking a guest that the picture appears zoomed in to show them larger than actual size, my guess is e-clip/circlip that retain the choke plunger spools.
Evilbay item number 115288353622
  • martin_csr
26 Mar 2022 08:08 - 26 Mar 2022 08:09
#864321
Taking a cue from Mikaw. See drawing reference numbers 92037 & 92037A.
1981 KZ650-CSR w VM24 carburetors:  www.partzilla.com/catalog/kawasaki/motor...retor-parts-kz650-h1
Last edit: 26 Mar 2022 08:09 by martin_csr.
  • gordone
26 Mar 2022 15:13
#864334
Thank you all !
Project:
  • PoodlePuncher
  • PoodlePuncher's Avatar
26 Mar 2022 17:44
#864344
I keep one of these sets on hand...   can find them pretty much anywhere for less than $10
Never know when you're gonna need one.
'75 KZ400S & '81 XS1100
  • davido
  • davido's Avatar
27 Mar 2022 07:25
#864365
They are used on the carb linkages. I know as one went flying across the room when I was seperating my carbs. I bought an assortment box of e-clips from;
www.toolstation.nl/set-locking-clips-e-model/p65099?searchstr=e
(I dont know if you have Toolstation in Norway?)
CB550 (1978)
CB500/4 (1972)*
KZ1000CSR (1981)
XT 600E (1999)
TDM900 (2003)
