seat lock key lost, how do I get seat off?
- 55xman
27 Feb 2022 11:58
I just purchased a 1980 KZ650CSR that has no keys and I need to get the seat off to install a new battery and remove the lock for re-kaying. I can't see any access to unlock the seat lock. Any advice?
Thanks!!!
Thanks!!!
- H1Vindicator
Re: seat lock key lost, how do I get seat off?
27 Feb 2022 14:51 - 27 Feb 2022 14:52
the ignition switch should have the key code stamped into it. hopefully it & the seat lock are original to the bike. or the helmet lock, not sure if it's removable without raising the seat. also the 650csr would be an 81 model. or 82 or 83.
Last edit: 27 Feb 2022 14:52 by H1Vindicator.
27 Feb 2022 14:54
The Key# is stamp on the lock cover and ignition switch housing. Any good lock smith can make a new key with the key#
- H1Vindicator
27 Feb 2022 15:01Please Log in or Create an account to join the conversation.
- Kidkawie
- I bleed premix
28 Feb 2022 18:20
Buy a pick set.
1975 Z1 900
1994 KX250 Supermoto
2004 KX125
2004 KX125
- ThatGPzGuy
01 Mar 2022 05:46
If you get the key code, you might be able to find a used set on eBay. There is also a seller on ebay who will cut you a new one for $15. I'd post the link, but this forum does not do ebay well.
Jim
North GA
2016 Yamaha FJR1300ES
1982 GPz750 R1
1974 Kawasaki H1
1976 Kawasaki KZ400
1979 Yamaha XS650 cafe'
2001 KZ1000P
2001 Yamaha YZ426
1965 Mustang
1967 Triumph GT6
1976 Bronco
North GA
1982 GPz750 R1
1974 Kawasaki H1
1976 Kawasaki KZ400
2001 KZ1000P
2001 Yamaha YZ426
1965 Mustang
1967 Triumph GT6
1976 Bronco
01 Mar 2022 07:39
PM rstnick, he makes keys
- willemZ900
- Z1B 4 ever
01 Mar 2022 13:56PM rstnick, he makes keys
Rstnick is the guy to go, he made me a perfect ignition key just by number
- Injected
02 Mar 2022 12:03 - 02 Mar 2022 12:05
You can't access the hinge bolts or the lock barrel bolt when the seat is down and locked. The only way to raise the seat without a key is to cut the seat cover off, remove the foam revealing the nuts for the seat lock clasp on the seat base. You would only do that if the cover was wrecked or you wanted to recover it.
Sometimes the key on the ignition does not match the seat lock.
If the key number is not on the face of the lock cylinder, you can read it with a mechanics mirror on the body of the lock cylinder.
1978 KZ650B2 modified project
1981 Z50R Honda tow bike
Last edit: 02 Mar 2022 12:05 by Injected.
- rstnick
04 Mar 2022 06:59
I can make keys by the key code number.
Making a key by the code number. - KZRider Forum - KZRider, KZ, Z1 & Z Motorcycle Enthusiast's Forum
Rob
CANADA
2000 ZRX1100
2011 Ninja 250R - Wife's
2005 z750s
1978 KZ1000 project
1983 KZ1000R2 Project
CANADA
2000 ZRX1100
2005 z750s
1978 KZ1000 project
- PoodlePuncher
07 Mar 2022 20:54 - 07 Mar 2022 20:57
Sounds like the perfect opportunity to learn how to pick locks
Basic Pick Set
While you're waiting for the newly cut key to arrive
Basic Pick Set
'75 KZ400S & '81 XS1100
Last edit: 07 Mar 2022 20:57 by PoodlePuncher.
08 Mar 2022 05:50
They are wafer locks. Pretty easy to pick.
