Help needed - Master-cylinder rubber seal
- H1Vindicator
Re: Help needed - Master-cylinder rubber seal
20 Feb 2022 08:09 - 21 Feb 2022 06:46
J3 has the same piston assy as the J1/J2 & a bunch of other dual disk models, so it's probably 16mm.
Last edit: 21 Feb 2022 06:46 by H1Vindicator.
The following user(s) said Thank You: Claude.
- Claude.
20 Feb 2022 09:01
I don’t know what’s J’s OEM diameter. I’ll try to find the info or measure one I have here.
2023 Honda CB500X
2017 Versys 1000
1982 KZ1000J2
1983 KZ1000J3
1982 KZ1000J2 (a second one!)
2017 Versys 1000
1982 KZ1000J2
1983 KZ1000J3
- Claude.
20 Feb 2022 12:58 - 20 Feb 2022 13:10
I have here a quite old master-cylinder that I believe is coming from a 1983 KZ750L which incidentally, have the same exact p/n than a 1983 1000 J3. J1/J2 have another p/n.
I just took apart and measured the piston and bore and it is less than 16mm. So, more than likely, it is a 15.87 mm.
Then, if I take the same road than ZRX guys, a 14 mm diam. master-cyl. will work.
Many thanks for all your comments!
2023 Honda CB500X
2017 Versys 1000
1982 KZ1000J2
1983 KZ1000J3
2017 Versys 1000
1982 KZ1000J2
1983 KZ1000J3
Last edit: 20 Feb 2022 13:10 by Claude..
20 Feb 2022 13:50
I think the main difference between the J1/J2 and the J3 is the brake light switch. The J3 uses the more modern switch that attaches to the bottom of the master cylinder and is activated by the brake lever.
- Claude.
20 Feb 2022 16:21 - 20 Feb 2022 16:21What about J1/J2 switch? Is it a fluid pressure switch?I think the main difference between the J1/J2 and the J3 is the brake light switch. The J3 uses the more modern switch that attaches to the bottom of the master cylinder and is activated by the brake lever.
2023 Honda CB500X
2017 Versys 1000
1982 KZ1000J2
1983 KZ1000J3
2017 Versys 1000
1982 KZ1000J2
1983 KZ1000J3
Last edit: 20 Feb 2022 16:21 by Claude..
- H1Vindicator
20 Feb 2022 18:09 - 21 Feb 2022 06:47
no. it has the same type of electro-mechanical switch as most other KZs and operates electrically pretty much the same as the modern style J3 switch. you should be able to hook it up exactly the same.
Last edit: 21 Feb 2022 06:47 by H1Vindicator.
- danr123
24 Feb 2022 13:12
HELLO I READING YOUR POST FOR A PART TO MASTER CYLINDER
THE RUBBER YOU NEED IS JUST FOR DUST AND IT SERVE FOR NO PRESSION ON MASTER
HELLO
MY VINTAGE KAWASAKI KZ400 1978
- H1Vindicator
24 Feb 2022 13:25
dust seal helps to keep the piston & brake fluid clean.
- Claude.
25 Feb 2022 14:09
TexasKZ, fyi, I ordered a dust seal for an EX500 and it fits right in. My MC is not an EX500 OEM but the seal fits anyway. Thanks for the hint!!!
2023 Honda CB500X
2017 Versys 1000
1982 KZ1000J2
1983 KZ1000J3
2017 Versys 1000
1982 KZ1000J2
1983 KZ1000J3
25 Feb 2022 14:46
Hurray for simple solutions!
