need tips on buying spokes 1977 kz1000a1
  • Gdizard
  • Gdizard's Avatar Topic Author
  • 12/03/1954
17 Feb 2022 08:21 - 17 Feb 2022 08:25
#862487
Does anyone have experience with picking the right place to buy spokes ?
I have a stock wheel and the rim is ok looking but the spokes are a bit either rusty or corroded so I want to replace them with new ones. I see where Buchanan in Azusa Ca. is a top seller but I just thought someone here might be more familiar with this topic.
Thank you
Last edit: 17 Feb 2022 08:25 by Gdizard.
  • slayer61
  • slayer61's Avatar
  • KZR FLAG RELAY CARRIER #62
Re: need tips on buying spokes 1977 kz1000a1
18 Feb 2022 07:15
#862514
www.buchananspokes.com/categories/index.asp
Yes. Absolutely go to Buchanan for spokes. I have used them several times in the past for weird concoctions. (I have hub X and rim Z, for example) and they sent the spokes to make it happen.  You couldn't do better
  • Kidkawie
  • Kidkawie's Avatar
  • I bleed premix
18 Feb 2022 19:45
#862544
Buy stainless spokes.  I've used many brands (Excel, Pro Wheel, etc), Buchannon isnt the only game in town.
1975 Z1 900
1994 KX250 Supermoto
2004 KX125
  • slmjim+Z1BEBE
  • slmjim+Z1BEBE's Avatar
  • Away
20 Feb 2022 06:21
#862613
Sometimes an owner simply wants a daily rider to look better without much outlay in time & materials. There's a quick & dirty way to make spokes look much better without replacing them.
Solvent-based aluminum paint.  Small jars of just a few ounces can be purchased at hobby shops and some hardware stores.  A small hobby brush, a little thinner to clean the brush when done, and a couple hours to paint the spokes is all that's needed.  From 10 ft. at a glance it will make spokes look pretty good on a budget.
We'd only suggest this if the spokes are straight & sound, and also if the nipples aren't seized with rust, so that spoke tension can still be adjusted.  True the wheel before painting.
Good Ridin'
slmjim & Z1BEBE
1973 ('72 builds) Z1 x2
1974 Z1-A x2
1975 Z1-B x2
1993 CB 750 Nighthawk x2
2009 ST1300A
www.kawasaki-z-classik.com
  • danr123
  • danr123's Avatar
24 Feb 2022 12:35
#862872
HELLO   MY FRIEND    I REBUILD MY FRAME ON MY VINTAGE KAWASAKI 1978  KZ400 B
I GO TO SEE MY INVOICE WHEN I'M PURCHASING THE SPOKE TO HELP YOU   I'M COMMING BACK
HELLO
MY VINTAGE KAWASAKI KZ400 1978
