OEM shock reassembly
  • Claude.
  • Claude.'s Avatar Topic Author
15 Feb 2022 08:21 - 15 Feb 2022 08:23
#862408
I'm currently restoring a 1983 J3 and today, I took one shock apart to clean/paint it. Like a stupid donkey, I forgot to take pictures on how the parts were indexed regarding the damping adjustment.
So, my question is: Does someone knows how to index the plastic ring, the shock head's small gear (yellow arrow) and the position of the damping rod that goes through the shock shaft?
I need to know in order to be sure dampening force will correspond to the chromed cover's 1-to-5 numbers.
NOTE: Even if I took pictures, I'm very interested to know how to index the damping adjustment parts.
Many thanks! [img] live.staticflickr.com/65535/51882613732_c2ccbf0094_b.jpg[/img ]
2023 Honda CB500X
2017 Versys 1000
1982 KZ1000J2
1983 KZ1000J3
1982 KZ1000J2 (a second one!)
Last edit: 15 Feb 2022 08:23 by Claude..
The following user(s) said Thank You: KZmarcel
  • Scirocco
  • Scirocco's Avatar
  • Premium Member
  • Premium Member
Re: OEM shock reassembly
15 Feb 2022 09:39 - 15 Feb 2022 09:39
#862413
Install only the upper shock mount/damping adjuster part without the spring. Turn the small gear in small steps to index the end to end position of the #1 min. to #5 max. damping effect by simultaneously pull and push the damper rod.
Last edit: 15 Feb 2022 09:39 by Scirocco.
  • Mikaw
  • Mikaw's Avatar
15 Feb 2022 10:53
#862417
Those are Showa shocks. These guys stock a lot of parts maybe they can help.
www.teknikmotorsport.com
hopefully you only took one apart at a time. Carefully inspect the other for a way to reassemble
  • Claude.
15 Feb 2022 18:53
#862442
When you says to simultaneously pull & push the damper rod, you mean to do this to feel the damping and where it is min and when it is max?
I already did this but did not feel noticeable difference. I will do it again with more attention to the difference.
Thanks!
2023 Honda CB500X
2017 Versys 1000
1982 KZ1000J2
1983 KZ1000J3
  • Claude.
15 Feb 2022 18:57
#862443
Only one at a time. You can see the other (assembled) shock on the picture I posted.
2023 Honda CB500X
2017 Versys 1000
1982 KZ1000J2
1983 KZ1000J3
