Petrified Exhaust Pipe Gaskets
  • McThing
  • McThing's Avatar Topic Author
30 Jan 2022 10:55
#861467
Hi all,
Anybody know the “right” way to remove the four ancient tubular exhaust gaskets between the 2 & 3 header pipes and the crossover pipe assembly and between the pipe assembly and the mufflers?
I dropped the whole system the other day and the old, probably original, gaskets are pretty much fossilized. I’ve gone at them with chisels, a flat edged screwdriver, and a utility knife and made some progress but I don’t want to get too aggressive and start deforming or seriously scratching anything. Some of it is on there pretty good and I don’t think I will be able to even catch an edge without getting close to the whacking too hard. It’s particularly challenging on the pipes where the gasket fused on the ID.
All the best,
B
1983 KZ750N2 Spectre
Baltimore, Maryland - USA
  • Street Fighter LTD
  • Street Fighter LTD's Avatar
  • Moderator
  • Moderator
Re: Petrified Exhaust Pipe Gaskets
30 Jan 2022 11:30
#861471
Wire wheel
The following user(s) said Thank You: McThing
  • Nessism
  • Nessism's Avatar
  • Away
30 Jan 2022 12:07
#861478
I think those gaskets have steel mesh in them.  A dremel cutoff wheel should hack through easily enough.  There may be asbestos in them, so try not to breathe the dust.
