Wheel swap
- Mtl1000
Wheel swap
11 Jan 2022 08:13
This topic has been talked about but I still need some clarification. I want to swap my 16 inch to a 18 inch from a z1r on to my 1980 Ltd 1000 . After research the only thing I see different is the collar spacer . Now after more research the calipers and rotors are different . What are the differences in caliper and rotor and can I use the ones from my 16 inch mag . Or maybe get the caliper from a kz1000 with the 18 inch spoke wheels , I think I’ll have a hard time getting the caliper and rotor from the z1r Thank you
Attachment not found
- DOHC
- Those Doe-Hawks really go!
Re: Wheel swap
11 Jan 2022 11:09The LTD caliper is smaller and more square than the Z1R (and KZ1000A) rear caliper. The rotor I think has a different offset from the mounting flange. So I think you'd have to replace them both as a set.What are the differences in caliper and rotor and can I use the ones from my 16 inch mag . Or maybe get the caliper from a kz1000 with the 18 inch spoke wheels , I think I’ll have a hard time getting the caliper and rotor from the z1r
It might not be that hard to find a Z1R style rotor and caliper. The parts used on the Z1R were the same as the standard KZ1000A from 77-80. They are fairly common, maybe more common than the LTD calipers.
'78 Z1-R in blue
, '78 Z1-R in black,
'78 Z1-R in pieces
My dad's '74 Z1
'00 ZRX1100
My dad's '74 Z1
'00 ZRX1100
- DOHC
Re: Wheel swap
11 Jan 2022 11:15 - 11 Jan 2022 11:15
Here are examples of both:
LTD: ebay.com/itm/363680468203
Z1R/KZ1000A : ebay.com/itm/403260458179
'78 Z1-R in blue
'78 Z1-R in pieces
My dad's '74 Z1
'00 ZRX1100
My dad's '74 Z1
'00 ZRX1100
Last edit: 11 Jan 2022 11:15 by DOHC.
The following user(s) said Thank You: Mtl1000
