1981 KZ 1000 LTD front forks/tree on 1978 KZ 1000 LTD
  • LATER
  • LATER's Avatar Topic Author
09 Jan 2022 17:16
#860308
Has anyone put the front forks, possably trees from a 1981 LTD on a 1978 LTD? The 81 has a leading axle, which im sure would slow down the steering. Thankyou to all of you!
  • 750 R1
  • 750 R1's Avatar
Re: 1981 KZ 1000 LTD front forks/tree on 1978 KZ 1000 LTD
09 Jan 2022 19:25
#860310
The bikes with a leading axle usually have different triple clamp offset to compensate, check the trail numbers of both front ends, less trail = quicker steering
The following user(s) said Thank You: LATER
