Brake calipers kz1000
  • Samminorwich
  • Samminorwich's Avatar Topic Author
20 Dec 2021 09:29
#859353
Hi is it possible to swap.round fork legs and fit my calipers in the position like a kz900 my bike is a kz1000A it came with the calipers behind lower leg so i don't know if this is right for the 1000A and if I can change positionĀ
cheersĀ
  • Mikaw
  • Mikaw's Avatar
Re: Brake calipers kz1000
20 Dec 2021 11:38
#859356
What year. 1977 A1 had single LH brake in front and the 1978 A2 had a single LH mounted to the rear. All years LTD had dual brake behind the fork. Also the 1979-1980 A3 & A4 had dual behind
  • 750 R1
  • 750 R1's Avatar
20 Dec 2021 14:01
#859372
Sam, most people would want the calipers at the rear, that's the optimal position and the reason all motorcycles of the past 40 odd years have them there....
I used to reverse the forks on my Honda 4's in the early 1980's to put the calipers at the rear, I had to use aftermarket front guards as the guard mounts didn't work properly backwards.
I'd just leave them as is...
  • MLMG
  • MLMG's Avatar
  • See you in the wind.
12 Jan 2022 10:54
#860455
How different is the position of the front brake caliper behind or in front of the fork? Thanks
1977 Kawasaki KZ1000 A1
