FRONT BRAKE SEAL KZ400
- danr123
04 Dec 2021 02:21
hello
I REBUILT MY FRAME ON MY VINTAGE MOTORCYCLE KZ400 1978
NOW I REBUILT THE FRONT BRAKE AND I NEED A SEAL FOR MY CALIPER PISTON
ON PART DIAGRAM 7) SEAL FRICTION 43049-1001
10) RING PISTON SEAL 43049-1001
11) SEAL 43083-002
www.partzilla.com/catalog/kawasaki/motor...kz400-b1/front-brake
WHERE I CAN FIND A SEAL KIT TO FIT ON
I WANT TO A MEASUREMENT TO O.D I.D.
11) SEAL 43083-002
HELLO
MY VINTAGE KAWASAKI KZ400 1978
- ThatGPzGuy
Re: FRONT BRAKE SEAL KZ400
04 Dec 2021 08:50
If they are the same as my 76D3 then they have been NOLA for years. I'm adapting a EX500 caliper to work on my KZ400.
There is a guy on eBay who is selling a seal that is supposed to work but I didn't have any luck with it.
Jim
North GA
2016 Yamaha FJR1300ES
1982 GPz750 R1
1974 Kawasaki H1
1976 Kawasaki KZ400
1979 Yamaha XS650 cafe'
2001 KZ1000P (sold)
2001 Yamaha YZ426
1965 Mustang
1967 Triumph GT6
1976 Bronco
North GA
1982 GPz750 R1
1974 Kawasaki H1
1976 Kawasaki KZ400
2001 KZ1000P (sold)
2001 Yamaha YZ426
1965 Mustang
1967 Triumph GT6
1976 Bronco
- Michel3007
12 Jan 2023 11:16
Any luck in adapting that EX500 caliper ThatGPzGuy ?
I have a 400 B2 and cannot find a proper piston and seal replacement... I would love to find a solution that doesn't involve swapping the entire front end just to fit a caliper..
Cheers
Cheers
KZ 750 H2 LTD 1981
GPZ750R1 1982
GPZ750R1 1982
- Kelly E
12 Jan 2023 11:35
Have you tried brakecrafters.com? They helped me source stainless steel caliper pistons and seals for my 77' KZ 1000LTD. They also helped me figure out what rear brake caliper I have, it is not what the manual says. It turned out to be from a KZ 750. It's the original caliper and mount, the bike has been in the family since new.
1974 Honda CB 550 K0
1977 Kawasaki KZ 1000 LTD
1978 Kawasaki KL 250
1980 Suzuki GS 1100E
1983 Honda CB 1100F
1984 Honda Sabre 700
1984 Honda Interceptor 1000
1990 Moto Guzzi 1000
And more
1983 Honda CB 1100F
And more
- ThatGPzGuy
12 Jan 2023 13:34Sadly, no. I've been busy on other projects. There was a write-up on how to do it on KZ400.com but that site has been problematic. I did do the conversion on my H1 so I know how it is done and it is not complicated.Any luck in adapting that EX500 caliper ThatGPzGuy ?
Cheers
Jim
North GA
1982 GPz750 R1
1974 Kawasaki H1
1976 Kawasaki KZ400
2001 KZ1000P (sold)
2001 Yamaha YZ426
1965 Mustang
1967 Triumph GT6
1976 Bronco
North GA
1982 GPz750 R1
1974 Kawasaki H1
1976 Kawasaki KZ400
2001 KZ1000P (sold)
2001 Yamaha YZ426
1965 Mustang
1967 Triumph GT6
1976 Bronco
- Michel3007
12 Jan 2023 14:38
Was the conversion like what's on this video ? :
Thank you Kelly, I actually already contacted Brakecrafters, following your advice in a topic I started regarding the KZ400 B caliper !
But unfortunately they do not have pistons nor seals for this model...
KZ 750 H2 LTD 1981
GPZ750R1 1982
GPZ750R1 1982
- ThatGPzGuy
13 Jan 2023 05:51YesWas the conversion like what's on this video ? :
Jim
North GA
1982 GPz750 R1
1974 Kawasaki H1
1976 Kawasaki KZ400
2001 KZ1000P (sold)
2001 Yamaha YZ426
1965 Mustang
1967 Triumph GT6
1976 Bronco
North GA
1982 GPz750 R1
1974 Kawasaki H1
1976 Kawasaki KZ400
2001 KZ1000P (sold)
2001 Yamaha YZ426
1965 Mustang
1967 Triumph GT6
1976 Bronco
- Sdaniels2010
14 Mar 2023 16:46
Will a caliper from an 81 KZ440 LTD work on your bike? I've got one currently sitting that worked perfectly before putting something else on.
1981 KZ440 A2 LTD
15 Mar 2023 07:52 - 15 Mar 2023 07:56
From the Partzilla link above the piston ring seal is part #43049-004 (not -1001) (#10 diagram ref number).
Someone on another forum posted that a Harley-Davidson 44047-83 piston seal will work (the square cut o-ring).
He didn't mention the other rubber parts. But the friction seal is readily available for cheap on EB; the other one is there as well but $$$ pricy.
Last edit: 15 Mar 2023 07:56 by martin_csr.
- Michel3007
15 Mar 2023 12:34
Hi Daniels,
No, it would not work. In order to fit a kz400H LTD or kz440 LTD caliper, this fork swap is needed : kzrider.com/forum/5-chassis/597812-kz400...r-fork-swap-tutorial
I haven't done it, I actually found suitable seals and a piston but I need to install a MC repair kit before testing them and haven't found the time to do so.
I will let you know if that worked!
KZ 750 H2 LTD 1981
GPZ750R1 1982
GPZ750R1 1982
- Michel3007
26 Jul 2023 09:27
Hi all,
Just wanted to update this thread.
The replacement seal and piston I ordered did not work, unfortunately so I moved on from it and completed the fork swap linked in my previous thread.
I did have a set of fork legs from a KZ400H with the front axle and front caliper which made it straightforward and cheap.
This was easier than I thought so, for anyone contemplating doing it, I would say go for it.
One thing I did different however, instead of opening up the fork boot axle diameter to fit my KZ400B front axle, is to fit wheel bearings that would accomodate the KZ400H front axle.
Which means I used both KZ400H fork boots, the 400H front axle and caliper, and the only mod I had to do on the left fork boot was to mill down the caliper mounting bosses.
Following Fiddles tutorial, I then added a spacer to centre my front wheel and that was it.
Cheers
Cheers
KZ 750 H2 LTD 1981
GPZ750R1 1982
GPZ750R1 1982
The following user(s) said Thank You: ThatGPzGuy, TexasKZ, LuisLAN
