!980 KZ 750 changing front shocks
  • JAYBAR
  • JAYBAR's Avatar Topic Author
01 Dec 2021 18:13
#858528
Converting an LTD to a cafe racer which front end would work the best. I found that the GSXR was to pricey so here I am again. Thanks for the other input.
  • Mikaw
  • Mikaw's Avatar
Re: !980 KZ 750 changing front shocks
02 Dec 2021 12:20 - 02 Dec 2021 12:22
#858551
Zx6r is a commen swap. Shorter in length but some support for off the shelf parts. ZX9R are the closet in length.
cognitomoto.com/products/zx-6r-fork-on-k...ersion-stem?variant= 39276633653363
There is a member here selling a set of ZX6r forks.  www.kzrider.com/forum/forum-index/23-for...rker-header-for-sale
Last edit: 02 Dec 2021 12:22 by Mikaw.
  • 750 R1
  • 750 R1's Avatar
02 Dec 2021 14:11
#858556
Front forks, not shocks, shocks are on the rear.  By the sound of things you want a bolt on conversion, no such thing without spending a lot of money. If you're looking for any front end, you need to match bearings, possibly change the stem, axle differences, front wheel spacers, speedo drive, and sort out steering stops, not to mention getting acceptable offset and trail.  If you don't have fabrication skills, this can also become expensive, just use the front end on the bike you have until you're ready and informed enough to do all the work.
The following user(s) said Thank You: JAYBAR
