Brake hose material
- Ojisan rider
Brake hose material
29 Nov 2021 01:35
Aloha guys,
Just as the title reads, I'm looking for what rubber type material can be use for brake hose. Now, before all of you start freaking out, what I'm trying to do is to replace my old rubber-turned-into-plastic, all cracked up rear reservoir line with new one. According to Partzilla, new one is not available, so just looking to see what's available.
Anybody know where I can get one? I found couple on ebay but seller didn't say what are they made from. maybe cut up a old brake hose (planning to run braided line anyway)?
82' KZ750-R1 cafe racer style. Clip-on, Rear set, Fork-Brace, Mikuni Flat-slide (forgot the size), Kerker.
84' GPz750 (basket case). everything are in pieces.
89' ZX750-H1 (ZX-7 Ninja). Resurrection project are on going with my KZ750. Everything is stock.
Re: Brake hose material
29 Nov 2021 05:16 - 29 Nov 2021 05:20
You can get a proper brake hose from various places. Z1Enterprises.com carries Goodridge which is what I installed. CycleBrakes.com has Gaffer brake lines w the fittings already crimped on. As to your question I'd guess the material would have to be reinforced rubber w a known burst strength or something like that. just guessing which is not good for the brakes. ha ha.
Last edit: 29 Nov 2021 05:20 by martin_csr.
- DOHC
- Those Doe-Hawks really go!
29 Nov 2021 05:32 - 29 Nov 2021 05:33
I've tried to answer this question in the past. The trick is that it's hard to know what you're buying, since there are so many different rubber compounds and things can easily get mixed up.
My best suggestion is to find a newer bike with a long reservoir tube and buy that part and cut it to your length.
For example, the EX500 rear master has a very long reservoir tube.
eBay.com/itm/265042919921
I think this part is part number 43059-1780, but double check.
www.partzilla.com/product/kawasaki/43059-1780
The high pressure breaker lines likely won't work. The inside diameter is very small. I can't see it fitting over the reservoir nipple.
'78 Z1-R in blue
, '78 Z1-R in black,
'78 Z1-R in pieces
My dad's '74 Z1
'00 ZRX1100
My dad's '74 Z1
'00 ZRX1100
Last edit: 29 Nov 2021 05:33 by DOHC.
- Ojisan rider
29 Nov 2021 23:26
Thanks guys. Guess I'll go with what DOHC recommend, just to be sure.
Yeah, I was thinking abvout the same thing. Unless you get it from reputable shop (like Grainger or similar), you'll never know what material even when the seller claim it's the right material. I'll just get from the newer bike. I was hoping I can get a bulk from somewhere. Need it for two bikes (my KZ and 89' ZX-7) and keep some as spare.
- ThatGPzGuy
30 Nov 2021 05:22
McMaster-Carr
has all kinds of bulk tubing. I saw a flexible tubing for hydraulic oil but I don't know if brake fluid would attack it or not.
Jim
North GA
2016 Yamaha FJR1300ES
1982 GPz750 R1
1974 Kawasaki H1
1976 Kawasaki KZ400
1979 Yamaha XS650 cafe'
2001 KZ1000P (sold)
2001 Yamaha YZ426
1965 Mustang
1967 Triumph GT6
1976 Bronco
North GA
1982 GPz750 R1
1974 Kawasaki H1
1976 Kawasaki KZ400
2001 KZ1000P (sold)
2001 Yamaha YZ426
1965 Mustang
1967 Triumph GT6
1976 Bronco
- DOHC
30 Nov 2021 18:31 - 30 Nov 2021 18:31
How about this place:
www.pegasusautoracing.com/group.asp?GroupID=RESERVOIRHOSE
They are a pretty legit race car parts supplier. I'd be confident that they are selling what they say they are.
'78 Z1-R in blue
'78 Z1-R in pieces
My dad's '74 Z1
'00 ZRX1100
My dad's '74 Z1
'00 ZRX1100
Last edit: 30 Nov 2021 18:31 by DOHC.
