Kz550 pivot shaft dimensions
- Sooper_arthur
15 Nov 2021 22:12
Hi, I'm looking to verify that 1980-81 kz550 rear axle is 15mm and I'm trying to find the length of it. If someone has one to measure... Or better yet sell, that would be greatly appreciated!
Re: Kz550 pivot shaft dimensions
16 Nov 2021 06:20 - 16 Nov 2021 06:29
Howdy. Partzilla lists the castle nut as 16mm. The axle part number is 41068-1086 & the cross-reference there at partzilla
says it was used on a bunch of 550/650/750 models, so you should be able to source one on EB.
Search eb by either part number or part name (KZ550 rear axle for example).
ps: topic title kinda confusing. pivot shaft would be the swing arm or center stand I guess.
Last edit: 16 Nov 2021 06:29 by martin_csr.
- JR
16 Nov 2021 09:37 - 16 Nov 2021 09:40
Yep same part # as many other bikes including the 1980 KZ750E1 as Martin said.
The shaft part of the bolt measures 29cm (or 11.5 inches). 30cm if you include the bolt head
There are a number of kz750 rear axles on ebay,com at the moment. When searching you only want the axle from 4 cylinder models
Last edit: 16 Nov 2021 09:40 by JR.
The following user(s) said Thank You: martin_csr
17 Nov 2021 06:02 - 17 Nov 2021 06:03
By JR: ... When searching you only want the axle from 4 cylinder models.
This, with one exception being the 82 KZ750 CSR Twin.
An earlier 750 Twin axle would be too big as these are 18mm.
The 83-84 750K Ltd Belt are 16mm but unknown length.
Whatever you get, double-check the x-ref before purchase. no sense goofing on something so mundane.
Last edit: 17 Nov 2021 06:03 by martin_csr.
The following user(s) said Thank You: JR
- Sooper_arthur
17 Nov 2021 17:22
Thank you for the responses. I apologize for the title. I'm actually planning on using the rear kz axle on the pivot shaft of the bike I'm building, must have been tired when I typed up the subject. But to verify, it looks like the early 80s rear axle is 16mm? And not the 15mm that I require.
18 Nov 2021 06:05 - 18 Nov 2021 06:05
Okay. I checked a few smaller models (250/305/440) but they're either 14mm or 16mm. I tried looking at some Hondas of the era, but the ones I saw were either 14mm or18mm. 14/16/18 might be a Japanese standard. guessing.
Last edit: 18 Nov 2021 06:05 by martin_csr.
