Tube vs tire size
  • Qsmothers3
  • Qsmothers3's Avatar Topic Author
Tube vs tire size
12 Oct 2021 12:57 - 12 Oct 2021 13:03
#856554
So on my 82 kz440 the rear tire is 130/90-16. Would a 130/90-19 tube work inside of it or no?
Last edit: 12 Oct 2021 13:03 by Qsmothers3.
  • DOHC
  • DOHC's Avatar
  • Those Doe-Hawks really go!
Re: Tube vs tire size
12 Oct 2021 13:28
#856556
No.  If you have a 16" diameter wheel, you need a 16" diameter tube.  And just to be clear the "-19" in 130/90-19 is the rim diameter.
Here are some that would work:
www.denniskirk.com/irc/16-in-inner-tube-...p54264.prd/54264.sku
www.denniskirk.com/drag-specialties/inne...35506.prd/535506.sku
www.denniskirk.com/michelin/standard-16-...40076.prd/540076.sku
My dad's '74 Z1
'00 ZRX1100
The following user(s) said Thank You: Qsmothers3
  • martin_csr
  • martin_csr's Avatar
13 Oct 2021 05:56 - 13 Oct 2021 06:16
#856583
Here's a heavy duty IRC tube from Z1Enterprises.com. 3mm thick. made in Japan & price looks good to me.
Other tubes are listed but didn't have much info & cost more.
www.z1enterprises.com/tube-tire-16-inch-...50-H1+650+CSR%2F1981
Last edit: 13 Oct 2021 06:16 by martin_csr.
