750H fuel range?
- BobZ
750H fuel range?
18 Sep 2021 05:25
I recently got my 82 750H LTD on the road...fuel light comes on at about 80 miles...have to go on reserve at about 90. That seems awfully low. Is that normal?
Had I known I'd live this long I'd have taken better care of my Led Zeppelin albums
1983 Goldwing Interstate
1982 KZ750 LTD
1982 KZ750 LTD
Re: 750H fuel range?
18 Sep 2021 05:41
Is the bike stock or modded?
The tank holds 3.3 gallons so figure about .75 gallons in reserve. 40 mpg gets you about 100 miles until reserve.
The following user(s) said Thank You: BobZ
- BobZ
18 Sep 2021 06:00Is the bike stock or modded?
Stock airbox, MAC header. Jets are all stock except for the secondary main...136 vs. 125. I guess the range is pretty much normal.
1982 KZ750 LTD
1982 KZ750 LTD
18 Sep 2021 06:31 - 18 Sep 2021 07:35
Yes, normal. Range anxiety is definitely an issue w a number of Ltd/CSR 4 cylinder models.
My 650-CSR gets around 45mpg mixed riding in town & 52 on the highway. still get nervous after 100 miles. same fuel tank as yours.
Last edit: 18 Sep 2021 07:35 by martin_csr.
- Lord Osis
21 Sep 2021 09:05 - 21 Sep 2021 09:09
And if you do a tank seal, you lose capacity and therefore range too.
One of the things I like about my '82 550 GPz is with it's 4.8 gallon tank and good gas mileage (it would get over 60mpg back when there was a 55 mph speed limit that was enforced, and if you beat the crap out of it you'd still get 45, 39 was the worst I ever got, 50-55mpg was normal) I could go well over 200 miles, once going just under 250 miles although really sore butt or arms was the real limiting factor, not the tank.
It always irritated me when a friend with a 650 would have to stop for gas and I'd be at least 100 miles from reserve.
Last edit: 21 Sep 2021 09:09 by Lord Osis.
- Elfarm98648
21 Sep 2021 21:49
I have an 81 kz750H. My standard is 40 miles to the gallon. I normally get 120 miles to EMPTY. when I say empty I mean won’t go another foot. To be safe I normally go about 100 miles in between fill ups.
