Master Brake Cylinder Diaphragm blues...
  • MartyZ1000
  • MartyZ1000's Avatar Topic Author
06 Sep 2021 09:07
#854904
I got a new diaphragm last year and now it´s like a swollen whate and won´t fit.
What is wrong? Rubber material or wrong .dot? I used 5, but the rubber must be of the
right kind too right? Where do I but good ones?
  • Nessism
  • Nessism's Avatar
Re: Master Brake Cylinder Diaphragm blues...
06 Sep 2021 09:40 - 06 Sep 2021 09:43
#854909
Did you use OEM parts?  The stock system is rated for DOT 3 fluid.  DOT 4 is okay too.  I've never heard of DOT 5 causing problems but maybe?
Last edit: 06 Sep 2021 09:43 by Nessism.
The following user(s) said Thank You: MartyZ1000
  • MartyZ1000
06 Sep 2021 09:58
#854911
I would if I could, do you have a source for that? I tried Ebay now and I found one seller and I´m pretty sure their gasket is not OEM,
probably like the last one that´s inflated by brake fluid now.
  • TexasKZ
  • TexasKZ's Avatar
06 Sep 2021 14:04
#854922
What year and model?
