Fork oil weight
- kzMax
Fork oil weight
09 Aug 2021 17:40
I am preparing to change the fork oil and seals on my 1982 KZ550 A3. My manuals say to use SAE 5w-20 oil, but I've noticed that fork oil is weighted differently from motor oil (5w, 10w, 15w, etc). Is it better to use dedicated fork oil, and if so, what would be equivalent to 5w-20?
Thanks!
Thanks!
1982 KZ550 A3
Central MA / Boston
Central MA / Boston
Re: Fork oil weight
09 Aug 2021 17:54 - 09 Aug 2021 17:55
I suggest 10 weight fork oil. And consider getting new fork springs which don't require any air to supplement the for springs. You can use 15 weight if you are a large rider and/or if you carry a passenger regularly, but the ride will be less compliant.
Last edit: 09 Aug 2021 17:55 by Nessism.
The following user(s) said Thank You: kzMax
- kzMax
Re: Fork oil weight
09 Aug 2021 18:09
I'm not a very large rider (6'2" 170lbs) so 10wt sounds good to me. Why do you recommend replacing the springs rather than adding air pressure?
1982 KZ550 A3
Central MA / Boston
Central MA / Boston
Re: Fork oil weight
09 Aug 2021 18:27Because the pressure leaks down and causes stiction on the seals. Get yourself some nice Sonic springs and problem solved for a nominal price.I'm not a very large rider (6'2" 170lbs) so 10wt sounds good to me. Why do you recommend replacing the springs rather than adding air pressure?BB
- kzMax
Re: Fork oil weight
09 Aug 2021 19:06
Interesting, I'll look into that.
1982 KZ550 A3
Central MA / Boston
Central MA / Boston
