750E swing arm dimension?
- Injected
09 Aug 2021 07:57
Can anybody confirm a dimension for me on a 1980-1982 KZ750E swing arm?
Need to know the distance between the pivot bolt center and the rear axle center at its minimum travel.
Thanks in advance.
Thanks in advance.
1978 KZ650B2 modified project
- Andy
Re: 750E swing arm dimension?
10 Aug 2021 08:20
Hi. I make it 45cm from the centre of the pivot bolt to the centre of the axle bolt when the axle is as far forward as it will go.
The following user(s) said Thank You: Injected
- Injected
10 Aug 2021 11:18
Perfect, Thanks.
