stem and head issues
  • kdoggin
  • kdoggin's Avatar Topic Author
05 Aug 2021 14:46
#853218
just got a kz 900 stem and it is the same as mine on my bike, forks slide into both but the stem center and head center are way off, please help anyone!
  • Scirocco
  • Scirocco's Avatar
  • Premium Member
  • Premium Member
Re: stem and head issues
05 Aug 2021 15:03 - 05 Aug 2021 15:12
#853220
Looks like your stem of the lower triple tree or fork legs are bend in a front collison.
Bent fork legs have a dent in the clamping area below the lower triple tree.
Loose the clamps, turn the fork legs and check if the stem center position to the upper triple center change.
Last edit: 05 Aug 2021 15:12 by Scirocco.
  • kdoggin
05 Aug 2021 19:09
#853235
it is possible, but I have  one same as  this one , 10.5 cm vs. 11 cm, steering center to fork center, I got a 1976 kz 900 head from old kawman,,has the 76 kz dash board rubber damped holes pn 44037-098
  • kdoggin
05 Aug 2021 19:11
#853236
I think i may have 2 bent heads, I will be sending back the latest,ouch
  • kdoggin
05 Aug 2021 19:12
#853237
sorry, stems
  • SWest
  • SWest's Avatar
  • 10 22 2014
06 Aug 2021 19:52
#853310
There's a upper and lower triple clamp. The steering stem is on the lower clamp. As suggested the forks may be bent or the lower clamp. Hold the lower clamp on a table and see if the two holes are flat then see if the stem is square to the table.
  • kdoggin
07 Aug 2021 03:01
#853318
nothing is bent.The center to of stem to center of fork is different as i measured. they are diff by half a cm. I have been informed that it is an early Z1 stem,  which makes sense because it had Z1 gauges  on it. the one from ebay is also a z1 stem , it was advertised as a 76-78 stem. Trying to return it.
i
  • hardrockminer
  • hardrockminer's Avatar
07 Aug 2021 04:54
#853323
As far as I know the offset on all Z1 models and on the KZ900 was the same.  Same rake, same trail, same offset.  Just different mount for the dash on the KZ900.  I believe the offset on KZ1000 models was also the same.  If you have a mismatched upper and lower triple tree then one of them is not from a Z1.  From memory, a Z1 offset is 60 mm.
  • SWest
  • SWest's Avatar
  • 10 22 2014
07 Aug 2021 06:34
#853329
I'd like to see the lower clamp. The Z1 has a hole where a steering damper connects to the lower tree.
  • kdoggin
07 Aug 2021 17:07
#853380
  • Mikaw
  • Mikaw's Avatar
07 Aug 2021 17:35
#853381
Is it possible you have an upper tree, (head) from a kz650. The meter mount the same, Partzilla says the 650 only fits the 650. Maybe the offset is different.
The following user(s) said Thank You: kdoggin
  • 750 R1
  • 750 R1's Avatar
07 Aug 2021 18:46
#853386
 You are correct, the 650 clamp has less offset, the 650 triple clamps were a common modification on the 900's for racing, my friend has 650 clamps on his 900...
