Wheels and sprockets
Re: Wheels and sprockets
09 Jul 2021 06:42I was out yesterday. At 5000 rpm I was doing 114 kph, measured with a GPS. But I gave bad numbers for my sprockets. I currently am using 16 & 35. (I had forgotten when I rebuilt the bike I used a Z1 sprocket to save a bit of money.) The bike has 630 chain.
That's 70.83632 MPH. I have a 15/35 and am doing that. Are you using the tranny you were talking about a while ago?
09 Jul 2021 19:00
09 Jul 2021 22:07
Now for some paint.
- ronnieV
10 Jul 2021 07:21
I'm in vacation till Monday,I'll get pics,what ever you think it's worth is good with me. Maybe keep a look out for a nice spoke rear wheel for my 77a
10 Jul 2021 19:02
Had some great weather today. Rode to my grandson Baseball game. Had lunch with my son, grandson and a few other baseball friends. So here’s what I have.
16” x 3.00 mag Enkie wheel
130/90 x 16 Pirelli Phantom tire
15/32 x 630 chain
78” circumference
25” diameter
4,500 RPM at 70 mph
15/32 x 630 chain
78” circumference
25” diameter
4,500 RPM at 70 mph
- Rick H.
11 Jul 2021 10:43 - 11 Jul 2021 10:45
Just to chime in, I went out today for a bit on my '77. At 60 MPH in 5th gear the tach is showing 4100 RPM. At 70 MPH in 5th gear it is showing 4600 RPM. I'm running pretty close to stock tires with 15/34 sprockets and 630 chain with a clip link master no less, but wired. I like staying below 5 grand for cruising speeds.
Rick H.
Rick H.
Rick H.
1977 Kawasaki KZ-1000A1
Last edit: 11 Jul 2021 10:45 by Rick H..
11 Jul 2021 11:55Rick you have an 18” spoke rear on your “A” model correct?Just to chime in, I went out today for a bit on my '77. At 60 MPH in 5th gear the tach is showing 4100 RPM. At 70 MPH in 5th gear it is showing 4600 RPM. I'm running pretty close to stock tires with 15/34 sprockets and 630 chain with a clip link master no less, but wired. I like staying below 5 grand for cruising speeds.
Rick H.
- Rick H.
12 Jul 2021 06:16
Yes Matt, 18" rear.
Rick H.
Rick H.
Rick H.
- willemZ900
- Z1B 4 ever
12 Jul 2021 10:22
Just read this thread, i am running a 16 wheel for one year, first with 15/35 but in my opinion to high revs on the highway. Now running 33 sprocket and perhaps change it to 32 teeth.Machine still accelerates fast (1015cc with vm 29 smoothbores)
- ronnieV
13 Jul 2021 12:05
This was on a 75 Z1 that was restored,18 inch ,not sure what it originally came off,I also have the matching front with twin disc.
- DOHC
- Those Doe-Hawks really go!
13 Jul 2021 12:41
It looks like an OE Kawasaki wheel. Does/did it have bead locks?
Could it be from a kz650-C? I think the 650 used a smaller drum than the 900/1000. What's the diameter of the drum?
The 2.15" width is the same as my '78 Z1R, so it should fit the stock size 900/1000 tire.
'78 Z1-R in blue
, '78 Z1-R in black,
'78 Z1-R in pieces
My dad's '74 Z1
'00 ZRX1100
My dad's '74 Z1
'00 ZRX1100
13 Jul 2021 12:57The KZ650-C models used disk brakes front and rear. EdIt looks like an OE Kawasaki wheel. Does/did it have bead locks?
