Steering head bearings
- Pattenrd
03 Jul 2021 11:01
Restoring 1978 KZ1000b replacing steering head bearings with all balls I got old racees out new one in big on bottom small on top lower bearing does seat all the way to bottom of stem does it get pressed on
Re: Steering head bearings
03 Jul 2021 11:22
Lower tapered bearing does press fit onto steering stem. Don’t forget the grease seal on before bearing.
- Pattenrd
04 Jul 2021 17:55
Thanks it went on real easy what a difference from roller starting to put part on instead of off currently own 1974 z1a 1978 kz 1000b
