Fork seals
  • Pattenrd
  • Pattenrd's Avatar Topic Author
Fork seals
01 Jul 2021 09:00
#851008
Replacing the fork seal on rebuild of 1978 kz1000  got front forks already disassembled had lowers powder coated putting all balls seals in which way do they go flat side spring up or down not to clear in sevice manual
  • Mikaw
  • Mikaw's Avatar
Re: Fork seals
01 Jul 2021 09:39
#851009
Spring down. Although I don’t recall ever seeing a spring but I only use OEM.
  • ghostdive
  • ghostdive's Avatar
Re: Fork seals
01 Jul 2021 10:18
#851011
Seconding Mikaw. I can say from personal trial and error that putting the seal in spring side up is a subpar plan.
2001 ZX-6R
The following user(s) said Thank You: Pattenrd
  • martin_csr
  • martin_csr's Avatar
Re: Fork seals
02 Jul 2021 05:45 - 02 Jul 2021 05:46
#851086
By Mykaw: Spring down. Although I don’t recall ever seeing a spring but I only use OEM.
OEM fork seals have the springs. probably to help them keep a good seal.
Orient downward so that the groove doesn't get filled with road grime & grunge.
www.partzilla.com/product/kawasaki/92049...7afa6001ea4c063c2d6b
Last edit: 02 Jul 2021 05:46 by martin_csr.
