New master brake cylinder + lever?
- Johio
12 Jun 2021 13:48
Hello
I have a 79 kz400 and I have kost the brake power. The lid of the brake fluid is leaking even tough i have replaced the seal.
Does anyone have a recomendstion about a replacement maste brake cylinder + lever? Something that fits with good quality?
Ebay has new ones for about $20 but can you trust the quality?
Best regards
Best regards
Re: New master brake cylinder + lever?
12 Jun 2021 14:42 - 12 Jun 2021 14:42Hello
Best regards
A Z1 OEM or repo MC would be a good replacement.
Last edit: 12 Jun 2021 14:42 by Scirocco.
12 Jun 2021 15:06
Master cylinders are extremely simple devices. Just about any master with a 14mm bore will work on your bike. If you have a mirror connected to the master be sure the new master has the proper threaded lug attached.
12 Jun 2021 15:58
