Lower fork tube assembly
  • Pattenrd
  • Pattenrd's Avatar Topic Author
07 Jun 2021 04:52
#849721
Took forks apart to powder coat lowers noticed arrows on bottom of forks what are they for
  • krazee1
  • krazee1's Avatar
Re: Lower fork tube assembly
07 Jun 2021 06:11
#849731
The arrows on the bottom of the fork clamps go forward.  The front nut is also tightened/torqued before the rear nut.
Mike
1974 Z1
1978 KZ1000 LTD
1976 KZ900B pile O parts
1980 KZ750E
The following user(s) said Thank You: Pattenrd
07 Jun 2021 07:59
#849741
Mike
Exactly!  I see so many images of KZ bikes that have the clamps installed wrong even though the Kawasaki Service Manual and the Kawasaki Owners Manual are VERY clear about how to install the clamps.  I guess folks either don't bother reading the manuals or somehow don't believe the manuals are correct?  Ed
  • Pattenrd
07 Jun 2021 09:14
#849745
Just finished 1974 z1a  don't remember seeing them thanks for the info have to get a newer manual
  • Rockranch
  • Rockranch's Avatar
07 Jun 2021 09:33
#849746
T'would be quite sad for a front wheel to fall off mid-wheelie!
(2)-1976 KZ900B-LTD's
1-all stock low mileage...
1 modified
1977 KZ1000 (awaiting resurrection!) :)
...and an old school Honda CB750 Chopper is next on my bucket list!
Oh...and a Pocket Rocket lol!!!
  • z1kzonly
  • z1kzonly's Avatar
07 Jun 2021 10:08
#849747
Just finished 1974 z1a  don't remember seeing them thanks for the info have to get a newer manual Z1 lowers did not have arrows. Started on76 KZ900’s.
just tighten front nut 1st. Rear will have a small gap
  • Mikaw
  • Mikaw's Avatar
07 Jun 2021 10:31
#849751
I smell a fact check!
  • krazee1
  • krazee1's Avatar
07 Jun 2021 13:09
#849772
I checked my Z1A fork clamps,  they are the only Pre-KZ forks I have, no arrows! All the other forks I have are 1976 and newer.  I believe Marty is correct!  IDK if that counts as a "fact check" or not?
Mike
1974 Z1
1978 KZ1000 LTD
1980 KZ750E
  • Mikaw
  • Mikaw's Avatar
07 Jun 2021 15:53
#849783
Good enough for me.
the manual states there is a front and a back, only determined once clamped down. If it’s on backwards the gap to the rear will be a wedge shape. If it’s installed correctly the rear gap will show both surfaces parallel. But there is nothing about an arrow.
Simon does drrrrawings!!!
  • slmjim+Z1BEBE
  • slmjim+Z1BEBE's Avatar
08 Jun 2021 04:57
#849809
There are no arrows on Z1 clamps.
To build on Mikaw's illustration, the flats on the clamp that meet the fork legs are two slightly different heights, or planes.  The taller side goes in front.  If you place a clamp on a flat surface with the flats facing down the difference in heights can be easily seen.
Good Ridin'
slmjim & Z1BEBE
1973 ('72 builds) Z1 x2
1974 Z1-A x2
1975 Z1-B x2
1993 CB 750 Nighthawk x2
2009 ST1300A
www.kawasaki-z-classik.com
The following user(s) said Thank You: Mikaw, Rick H.
  • Mikaw
  • Mikaw's Avatar
08 Jun 2021 08:45
#849820
Slmjim, might be stretching it a little identifying them as Illustrations. But thank you. You guys have to remember Mike Meyers on SNL as simon in the bathtub doing drawings. Youall missed it.
  • hardrockminer
  • hardrockminer's Avatar
08 Jun 2021 17:06
#849853
Not to upset the apple cart here, but a lot of Z1 owners turned their forks around.
