Tyres for KZ440
  • Pagala
  • Pagala's Avatar Topic Author
Tyres for KZ440
06 May 2021 15:13
#848102
Sorry for the stupid question, but I have the service manual (although not the user manual) for this bike and the information isn't in there. Plus I couldn't find the user manual online.
The bike is a 1981 KZ440C1. I don't believe you got these in America. But they use mag alloy wheels, 7-spoked.
The front wheel size is 3.00 18.
The rear wheel size is 3.50 18.
My question: do these require tubed or tubeless tyres?
They look like they would be OK to fit TL tyres.
The front tyre currently fitted is a TT. The rear tyre currently fitted is a TL. These are horribly mismatched cheapo tyres, and I want to replace them.
Ideally, I want quality TL tyres, but if TT is stipulated by Kawasaki then I'll go with that.
Anyone know about this stuff?
Thanks
1̶9̶8̶3̶ ̶K̶a̶w̶a̶s̶a̶k̶i̶ ̶G̶T̶5̶5̶0̶ ̶(̶U̶K̶-̶o̶n̶l̶y̶ ̶m̶o̶d̶e̶l̶)̶,̶ ̶a̶l̶s̶o̶ ̶k̶n̶o̶w̶n̶ ̶a̶s̶ ̶t̶h̶e̶ ̶Z̶5̶5̶0̶ ̶G̶1̶,̶ ̶r̶e̶g̶i̶s̶t̶e̶r̶e̶d̶ ̶i̶n̶ ̶1̶9̶8̶4̶.̶
1981 Kawasaki Z440 (KZ440C1)
  • Nessism
  • Nessism's Avatar
Re: Tyres for KZ440
06 May 2021 16:35
#848109
Unless the wheel has lettering that states "tubeless applicable" or something to that effect then it's originally speced to take a tube.  Lots of people have converted cast tube type wheels to run tubeless though so that's always an option too if you want to go down that road.  It's a simple mod that involves installing a tubeless valve stem after possibly modifying the stem hole as required.  Either way, tube or tubeless, you can run tires designated as "tubeless."
The following user(s) said Thank You: Pagala
  • ghostdive
  • ghostdive's Avatar
Re: Tyres for KZ440
06 May 2021 17:31
#848113
It's said (and probably will be repeated) that tubeless-type wheels will have an inner ridge on the bead seat, to hold the tire on in case of deflation. From personal experience, this isn't a sure thing - my tubeless front tire unseated while I was rounding a corner - so I would go ahead and use tubeless.
2001 ZX-6R
Re: Tyres for KZ440
06 May 2021 17:31 - 06 May 2021 17:31
#848114
Holy cow!  Those are HUGE wheel sizes for any KZ440.  I suggest you double check that info since I cannot believe it is correct.  Ed
Last edit: 06 May 2021 17:31 by 650ed.
  • Pagala
Re: Tyres for KZ440
06 May 2021 18:19
#848116
It is correct.
  • Pagala
Re: Tyres for KZ440
06 May 2021 18:20
#848117
Thanks guys. I think I'll shoot for tubed tyres, since these were probably the default.
  • Nessism
  • Nessism's Avatar
Re: Tyres for KZ440
06 May 2021 20:28 - 06 May 2021 20:29
#848128
I've never seen any KZ with wheels that wide.  Even the 1100.  Those must be tire sizes unless the bike has aftermarket wheels.
Last edit: 06 May 2021 20:29 by Nessism.
  • 750 R1
  • 750 R1's Avatar
Re: Tyres for KZ440
06 May 2021 20:36
#848130
Those are tire sizes, not rim sizes....
  • Pagala
Re: Tyres for KZ440
07 May 2021 05:17
#848139
Oh, you thought I meant the size of the alloy wheels minus the tyre...
Glad that's cleared up.
Re: Tyres for KZ440
07 May 2021 05:57
#848141
We thought you meant the size of the wheels because that's what you stated:
"The bike is a 1981 KZ440C1. I don't believe you got these in America. But they use mag alloy wheels, 7-spoked.
The rear wheel size is 3.50 18. "
  • Pagala
Re: Tyres for KZ440
07 May 2021 07:24
#848151
Well, that's special.
  • DOHC
  • DOHC's Avatar
  • Those Doe-Hawks really go!
Re: Tyres for KZ440
07 May 2021 12:39
#848175
It looks like if it's a 1981, it would be a KZ440-C2?
www.kz400.com/ModelidentificationFrameset.html
The 1981 KZ440-A2 LTD still shows tubes in the parts diagram on Partzilla.  1981 is when they started transitioning to tubeless, but it may be that the 440 still had tubes in 1981.
As Nessism said, if the wheels are made for tubeless use it should be stamped on the wheel, as this was a new advancement at the time.  If you don't see anything that says tubeless, they were probably made to use tubes.
You'll have more luck searching for metric sized tires as opposed to the older inch sizes.
For the front, 3.00-18 translates to roughly 90/90-18
For the rear, 3.50-18 translates to roughly 110/90-18  This is a bit wider, but closer to the correct diameter than a 100/90-18.  I'm not sure you can get a rear 100/100-18 these days.
My dad's '74 Z1
'00 ZRX1100
