79 KZ650C Rear Master Cylinder
  • Stefk88
  • Stefk88's Avatar Topic Author
13 Apr 2021 13:40
#846642
Hey everybody,
My KZ650C rear master cylinder is leaking. I had it bored and sleeved but I cannot find a piston or a cup that goes on the piston to get it to stop leaking. At this point I'd buy an aftermarket master cylinder, but they're all made in China and the reviews say they suck. Any suggestions?
  • Scirocco
  • Scirocco's Avatar
  • Premium Member
  • Premium Member
Re: 79 KZ650C Rear Master Cylinder
13 Apr 2021 16:24
#846647
Some pics of your the rear MC would help to get a replacement MC.
  • rstnick
  • rstnick's Avatar
  • Premium Member
  • Premium Member
13 Apr 2021 17:48 - 13 Apr 2021 17:50
#846650
This thread may be of some help:
KZ650C Rear Master Cylinder Rebuild Parts - KZRider Forum - KZRider, KZ, Z1 & Z Motorcycle Enthusiast's Forum
after you advised of this i went and bought one, it is the right diameter but length is shorter i dont know if this is a problem or not. i also picked up a 14mm front master cylinder for cheap and the seal is as far as i can tell the same size, the pic shows the 14mm front kawasaki seal on the left, the original seal on the piston (which to me looks in good nick) and the CBX on the right, as you see the CBX is shorter. I have cleaned the piston up more since the photo and it now looks fine, so i hope when i finally come to refit one of seals does the job, or even better they all will work.
Rob
CANADA
2000 ZRX1100
2011 Ninja 250R - Wife's
2005 z750s
1978 KZ1000 project
1983 KZ1000R2 Project
Last edit: 13 Apr 2021 17:50 by rstnick.
  • Mc Tavish
  • Mc Tavish's Avatar
14 Apr 2021 02:58
#846660
Nice of the company you used to bore and sleeve the M/C to dimensions that parts are no longer available!
1978 z650C
